Originally Posted by
JackRWB
Hi. Could you tell me please if you get any ABS sensor related errors? I have my A6 Allroad Quattro 3.0 V6 Bi Turbo 313BHP 2014 engine code CGQB.
I have the same issue. Christmas light and bloody annoying beeping. I tried almost everything. I've bought off ebay a used ABS pump with module and I swapped it. Still all the errors came back.
I've bought a new ABS/Speed sensor and plugged it in both sides to see if anything changed. No success. Now I'm waiting for a brake light switch as I read it can cause lots of trouble but I have no errors related to switch.
My ABS module simply loses communication and the computer cannot discover its presence. The interesting fact is that when I disconnect the ABS module plug and connect it again, then for a few minutes or seconds (always a surprise when) it gets back communication and I can read the codes related to lost communication with ABS module.
Does anybody have any idea what could be faulty? Is there a relay that might play with me or maybe the unit from ebay is also broken? I've never had any DTC related to bad sensor, bad wiring or anything like this.
Whoever will find the answer, will be rewarded
Hi, I got multiple lights, TPMS, stability control, traction control, parking brake, ABS. This first happened during lockdown in 2020 and I charged up the battery and everything cleared. Now the problem has come back (on a very cold morning), I tried charging the battery again but no luck. I ran a diagnotic on it and it came back with
Rear Right Wheel Speed Sensor C101D 07 (137) - Mechanical Failure
Wheel-Speed Signal from ABS Control Module P1887 00 (039) Implausible Signal
I've replaced the ABS sensor and even tried two different makes because the first didnt' fix it. I have also fitted a new battery to rule this out as my old battery was the original one and was 11 years old. Incidentally, I tested my old battery a few days later and its reading 12.58v so it's still a good battery.
When I pulled my new Bosch sensor out to fit a new Delphi one, I noticed that the Boash sensor had rust marks at the end and also score marks like something is catching it.
So this is why I am leaning towards a damaged and/ or corroded ABS sensor ring. I have booked it in my garage tomorrow because I couldn't get any answers on here or other forums about replacing the ring DIY. My mechanic says that he thinks it's ABS sensor ring too and he's done several on Audis. He even said it's a common problem here in UK for Audis. Anyhow, only time will tell and hopefully I can report back on Wednesday with some good news.
