Results 1 to 17 of 17
    Dec 24 2022
    San Antonio, TX
    Looking for recommendations on DS1/TCU tune
    Just picked up a 2015 S6. About to pull the trigger on SRM intakes and a flex fuel sensor/fuel lines. Looking for recommendations on custom DS1 tuning/tcu tuning. Whose the best and why?
    Registered User Four Rings John@DEADBEEF_DynoSp's Avatar
    Nov 01 2019
    Isle of Man
    There is a Facebook group for DS1 4.0T with 3000 members. If you can bear Facebook.
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Kyle Leblanc at Kyletunedit can get you DS1 and TCU
    Will Flores at SRM can get you DS1 and TCU
    Corey Harper at GPO can get you a DS1 and TCU
    Jon Gronewald at Pinnacle Performance can get you a DS1 and TCU
    Custom tune will be ok, but you really need to decide where you want to take the car. Are you a stage 1/2 and be done with it, if that is the case, then the DS1 OTS tune will be sufficient.
    it gets into a slippery slope past this, and the DS1 page John mentioned above has all of this you'll need to start to understand. the DS1 website also has the FAQ and read me sections which will cover nearly all your basic questions...so take some time to read here...I might know a thing or two about this.....my questions were answered very in depth in the FAQ and how to sections....lol
    https://www.facebook.com/groups/112464620100200
    Dont just start throwing parts at the car.....some parts will set you down a path and you'll end up spending more money going in another direction of where you want to take the car ultimately
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Upgrading the inlets and E85 is certainly a great place to start! You have done some homework it seems! I wouldn't get a custom tune just yet with those mods. S6 OEM turbos are not built for continual high(er) boost levels, reliably. If you are spending money on a custom tune, you should upgrade the main power-producing components to handle the fine-tuned increased power reliably (RS7 Turbos, PP, etc).
    Join the FB group, do some more research yourself first there. You'll get everyone recommending all the people Travis listed, and a couple more too.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Dec 24 2022
    San Antonio, TX
    Quote Originally Posted by THCarpenter View Post
    Appreciate all the info! The only reason for custom tune in the beginning will be to turn off CEL for downpipes, but 100% plan to go full retard with 3071's/A2A/Full fuel system with meth in search of 800+ awhp, so I figure it's best to start working with whomever is the best now and not later.
    Dec 24 2022
    San Antonio, TX
    Thanks for your input...my current stage 1 build plan is below...any recommendations?
    STAGE 1-550 whp
    Flex Fuel/Lines 500
    DS1/TCU Tune 2000
    SRM Intake 895
    Downpipe/Midpipe 1200
    Ebay Turbos 500
    Turbo oil lines 500
    HPFP 750
    Methanol Injection 1500
    Custom Tune xxx
    Jun 19 2018
    NH
    Quote Originally Posted by Paranoid View Post
    STAGE 1-550 whp
    Flex Fuel/Lines 500
    DS1/TCU Tune 2000
    SRM Intake 895
    Downpipe/Midpipe1200
    Ebay Turbos 500
    Turbo oil lines 500
    HPFP 750
    Methanol Injection1500
    Custom Tune xxx
    Good looking list. You’ll be at stage 3 after all these mods
    You’ll want to get the DSG serviced before you go this route, and replace spark plugs with a step colder; Brisk ER10’s are your best bet.
    Still a good idea to invest in a larger HX and coolant pump on an S6/7, even though you’re going with WMI. JHM, Merc make quality HX. SRM does also sell a kit if your budget is wide open, which it seems to be lol
    Dec 24 2022
    San Antonio, TX
    Quote Originally Posted by MattyMarkey View Post
    By DSG serviced you just mean a normal fluid/filter change or something more? I was already planning on doing the 75k mile transmission service in advance of doing the DS1/flex fuel.
    As far as the SRM Kit, I was considering it, but would rather save funds for stage 2 (my stage 2, not DS1 stage 2 tuning map) which would include the SRM A2A intercooler kit. From what I have read so far, the stock IC brick isn't that good, and the MERC one isn't any better, so I don't see the point in investing 2kish into the A2W system just to dump it later on when I put some decent sized turbos on.
    My thought process was just to spray a shit ton of meth along with E-85 and max out the Ebay RS7 turbos for 6 months to a year while I save up for some real turbos/fuel system/A2A...you don't think that will hold up?
    Jun 19 2018
    NH
    Yes, just a DSG service. Don’t forget about those spark plugs. Probably more important here.
    Missed that you wanted to go A2A. If that’s your plan, than you’re right, no need to waste your money. You will def want to log and make sure that’s the case anyway with E85/WMI.
    If you are going this deep in your goals, might as well get a better-sized turbo for the caliber of your mods. RS7 sized turbos will certainly work, but larger will better utilize what your planning to upgrade; EBay/Aliexpress sell larger than RS7 turbos too… a few more upgrades needed to support the required fueling, but goes with your custom tuning already planned
    Dec 24 2022
    San Antonio, TX
    Most definitely going to do the spark plugs at the same time as the turbos/oil lines! My reasoning for no larger than RS7 turbos to start is precisely the fuel system requirements. From what I can gather, doing E-85 with just HPFP pistons you are limited to RS7 sized turbos until you also do LPFP and lines. I'm trying to keep stage 1 of the build around 10kish, with real turbos/a2a and a complete fuel system coming in stage 2. Below is my stage 2 plans, sure I'm missing a few things...
    STAGE 2-850 whp
    GTX 3071 6000
    LPFP 2300
    SRM A2A IC 5995
    Tial Wastegates 895
    3 bar map sensors 600
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    I'm sure this has been answered but i can't seem to find it. i'm selling my car to a friend and he wants it stock is it ok to run a tcu with stock ecu? reason i'm asking is that boosted euro seems to be mia, i can't even get him to respond to any of my dm's or text.
    tia.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Jun 19 2018
    NH
    Quote Originally Posted by ichi d View Post
    tia.
    Boosted Euro is no longer in business, for reasons not fully known, but one can deduce why.
    Unfortunately, the tuner is really the one that could answer this definitively. Saying that, there are other tuning companies that also have DSG tunes, and it’s not recommended that a TCU tune is used without the ECU tune. I don’t have the BU TCU tune, but there’s no way for you to flash back the stock file on your own?
    Logically IMO, it shouldn’t hurt anything if you aren’t getting on it, but he wants it stock and doesn’t sound like he would want that long term
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    tia.
    Mirza is on the FB forums....make a public post in any of the C7 or S6 groups asking him....he comes in waves though....sometimes he is willing to help out....other times hes too busy for us peasants
    Jun 19 2018
    NH
    aka waste of time haha
    May 10 2013
    Toronto,ON
    Oh man this sucks. Anyone know if he is on ig? I don't have fb. I have epl software too but their severs are down like op said. :(
    Jun 19 2018
    NH
    Mirza still has Boostedeuro as an IG account, but no clue if he will respond there either
    May 10 2013
    Toronto,ON
    Nope he doesn't respond there either. I ended up calling a local APR dealer and they were able to flash it back to stock. Thank you everyone for your inputs!
