Wondering if I'm in the same boat as you. I bought the car used back in June as a CPO. Had some things looked at at an indy shop, they said my coolant was low so they topped off in October. I just topped it off again with about a cups worth of coolant to keep it close to max and above min.
I have no coolant smell and couldn't see much around water pump or thermostat, but I did notice some white residue around the same part you're having issues with. I'm unsure if it's just road salt or dried up coolant.
I'm curious if I could be losing that much coolant from the shut off valve. I will be monitoring the levels closely to see if it drops more. Sucks because I was about to tune the car but going to hold off.
Sent from my SM-G998U using
Audizine Forum mobile app
