Results 1 to 23 of 23
    Nov 08 2017
    Chicago
    Any luck with Powerstop Z26 to avoid the maddening squeaking??
    Folks,
    Previously some kind folks recommended the Power Stop Z36 pads when I had my brakes done. Shop went with Akebonos and I"m still getting the@%!##!%$ squeaking but they are up for replacing them. challenge is Power Stop only has Z26 pads in stock.
    Has anyone had issues with the Z26s?
    I have a 2018 S7.
    Apr 30 2019
    Southern California
    I've got the Z26 on my 2017 A7. Fairly low dust and silent.
    Sent from my Pixel 6 Pro using Audizine Forum mobile app
    Senior Member Two Rings sittinlow's Avatar
    Apr 08 2009
    Long Island
    I have them on a 16 S6, no squeaking and low dust.
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    z36 are for truck and towing. z26 are the ones you want. z23 are same as z26 except the z26 have metal backs to the pads were the z23 have rubber.
    i use the z23s 0 issues and dead silent
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    Quote Originally Posted by sittinlow View Post
    same here
    2016 S6 - sport - optx- atlas - AE nardo
    Junior Member Two Rings gweaver001's Avatar
    Mar 12 2020
    2017 Audi S6 Prestige, 2015 Q5 TDI P+
    Z26 is a popular choice. I went with EBC Redstuff and they are a great choice as well.
    2017 Audi █S6 Prestige | Black Optic | Sport | Driver Assist | Audi Design Arras Red | Red Carbon Atlas | H&R Sway Bars | PP RS7 Turbos | ECS Inlets | RS7 Airbox | DS1
    Sep 01 2022
    Houston Texas
    Quote Originally Posted by gweaver001 View Post
    I did the same. Perfectly silent and low levels of dust compared to stock
    Veteran Member Three Rings bpd's Avatar
    Feb 01 2017
    Seattle WA
    19K miles on my z26 and they are quiet on my '18 S6. Just had my 4yr service and they are 10mm front and back.
    2018 S6, 2023 S5 SB
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    They are incredibly noisy when very cold outside for like the first two stops but ok after.
    Never an issue in warmer weather though.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    2018 Z26. life changing.
    18 S6
    Feb 01 2021
    2013 Audi S7 & 2019 Audi Q7 3.0t Prestige
    North NJ
    Quote Originally Posted by Audisthesia View Post
    This x1000
    Oct 20 2016
    Los Angeles/CA
    I may be one of the very few that didn’t have luck with my Z26 pads - the first six months was great with just slightly less braking power but then the squealing got very bad if not worse than my OE pads.
    I recently got the girodisc pads which unfortunately dust up but are not squealing…yet
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    Another vote for the Z26. I got those and the cross drilled rotors from rock auto of all places. They aren't as grabby, but still stop a street car fine, they are quiet, and very little dust. They can still grab hard enough to engage the ABS system with pirreli p zeros and you still stop faster than 99% of the stuff on the road.
    I haven't used them in a high fade situation like the track or trying to rocket full blast down a mountain for 10 miles but overall I like them.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Jan 07 2021
    Florida USA
    I have a 2018 S7 myself and went with the Z26 all the way around and like everyone above, love how low dust they are. They are slightly less brake grippy up front, but still very good brakes. My only knock is that I get brake knock from my front brakes because the holes where the guide pins go through are a little larger than the OEM ones, so when you change directions in the car and start to apply the brake, you'll hear a little knock the first time you brake. I've looked into ways to fix this, but nothing I've found has eliminated it. The brake pads themselves are night and day difference when it comes to the brake dust for sure.
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Garyn06 View Post
    Did you remove the adhesive shim pucks? That's the only way I could see the pad moving around, otherwise they are pretty well stuck to the pistons regardless of the pins.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Feb 01 2021
    North NJ
    Quote Originally Posted by snohman View Post
    I have Girodisc rotors and started with EBC Redstuff with them. After 1k miles, pulled them cause they dusted like crazy and squealed. Then tried Girodisc Magic Pads and same issues…lots of squealing. Finally tried Z26 and have zero point zero issues…no dust, no squeal, and good stopping power AND the cheapest option.
    Jan 07 2021
    Florida USA
    Quote Originally Posted by gk1 View Post
    I didn't have any of the adhesive shim pucks in my calipers when I removed the calipers from the rotor and then removed the OEM brake pads from the caliper. So when I put the Z26 brakes in, I didn't use any since it didn't seem necessary from the OEM application. I have seen other posts from individuals stating the same with their brake replacement and various ways to try and solve it. some options have temporarily worked for me, but I have not had any long term solution.
    Feb 01 2021
    North NJ
    The shims are needed and worth the cost.
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Mikes281 View Post
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Established Member Two Rings cuerna's Avatar
    Jun 23 2010
    Lubbock, Texas
    I am installing new rear rotors (rockauto R1 concept drilled _slotted) and Z26 rear pads next week. I will report after bedding and testing...
    Nov 03 2019
    San Francisco
    Before you have a heart attack look at the Audi shims…buy thesehttps://www.ecstuning.com/b-uro-part...635208600~uro/
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Have the Z26's with cross-drilled Zimmerman's. Like everyone else, no squeaks, almost no dust, and have a click every so often when changing directions on the A6. They're more than adequate for street use. Spirited mountain driving, or braking when towing (roughly 1800 pounds) down long steep mountainous roads and they do start to glaze a bit. That being said, I'll be using them again when I upgrade the calipers to larger ones. Cleaning the brake dust from the stock pads every 2-3 days sucked.
    Put the Z23's on my father's GLK and they have way less stopping power for some reason, especially when compared to the Textar pads I took off. That being said, they didn't click when switching directions.
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by TheBlackMarvel View Post
    Yes I know.
    Bought them once at FCP when they were cheaper....will never have to buy them again.
    https://www.fcpeuro.com/Parts/?keywords=4H0%20698%20231
    Perf, Leather, Exec
    2015 S6 Quartz Gray
