Wondering if anybody can help me out here so I drive the b6 A4 1.8t had it for some years now late last summer I noticed a problem when I was on full throttle (any gear) mostly noticed in 3rd gear when applying full throttle the car seem to be surging like it was giving full power then letting off then giving full power again then letting off and this was with throttle fully open. No check engine lights on the dash no other symptoms. Then the cam chain tensioner failed and I had it replaced just the tensioner not the chain all was timed back up and running again but now I have a check engine light for p0171 and I have little to no boost or power.so I've cleared the code and took it for a run and the powers there again for a few minutes then it goes back too the lack of power and eventually the check engine light comes back on again. So far I've looked and listed for vacuum leaks I've changed the n75 valve for a new one, I found one split hose replaced that with one from an auto shop found another that didn't look great witch was connected to the crankshaft breather hose witch was also smashed so replaced that too I'm just stumped as to what it could be, I was thinking maybe the waste gate was at fault but after the code is clear you get a few goes at full throttle and all the power is back but then goes back into what I'm guessing is limp mode anybody have clue what could be causing this ?
