Results 1 to 23 of 23
    Established Member Two Rings blackincali's Avatar
    Oct 21 2018
    Nogaro Blue B6 S4, B6 A4 Ultrasport 3.0 6MT
    Houston, TX
    B7 RS4 Oil Consumption Issues
    I have a 2007 RS4. Purchased from the previous owner on BAT in June 2022 with 91K. Currently at 98K. The previous owner did lots of maintenance, like carbon cleaning at 86K. Don't think he deflapped. The car has been burning lots of oil, though. I have to top off every 500-600 miles or so. And I don't see any leaks other than a tiny one my mechanic noticed, which could be valve cover gasket. I drive spirited, but this seems abnormal. Running Pentosin 5w_40. Any advice on what to tell him next time I bring the car in for maintenance to tackle this issue?
    Dec 21 2016
    Louisville, KY
    No leaks? Done any oil analysis to see if there is any coolant migration? How about spark plugs, are they dry? I would say PCV first, then do valve covers and or cam girdle gaskets. If you get all the way to cam girdle gaskets then valve seals should probably be on the list. Slippery slope.
    Jan 22 2019
    Philadelphia, PA
    Did you ever drop the belly pan to see if the leak is pooling up there? My oil cooler pipe o-rings were leaking and it was hard to see the severity of the leak due to the angle I parked at and where it pooled on the pan.
    07 RS4 Mugello Blue - Billstein B14 Coils/GMG WC Exhaust/JHM SS + BFI Weighted Knob/LED tail lights/Enkei RS05RR 19x9.5 et25 wheels
    Oct 21 2018
    Houston, TX
    Haven't dropped the pan, but will check to see if oil is there.
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    Quote Originally Posted by blackincali View Post
    i have definitive proof from multiple blackstone UOA that 10w69 reduces wear PPM and oil consumption, for me it's liquimoly 10w69...simple ass mens
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Oct 08 2018
    Earth
    Quote Originally Posted by jonan View Post
    Can't imagine this can be ran in a cold climate?
    Aug 02 2019
    Midwest
    Hey, BMW does it. You can also look into the Motul 5w50. Still, the most important thing to consider is alignment with Audi oil certification and/or how well the additive package aligns with the factory-specified oil. You can try some Liqui Moly Engine Oil Saver additive as well but it's best to do with a fresh oil change.
    B7 RS4
    B6 S4
    Oct 21 2018
    Houston, TX
    I'll actually be bringing the car in for servicing soon and switching to LiquiMoly 5w_40 Molygen. I'm only using Pentosin because I want to use the same oil the previous owner was running. Oil is very dirty I noticed. Black. But I'm waiting for my mechanic to wrap up with other car so I can swap.
    Senior Member Two Rings RS4forfrank's Avatar
    Apr 27 2012
    2008 OEM+ RS4
    santa barbara california
    Hi Guys,
    Running into the same issue. Previously 900-1000 miles would need a quart, now it's about 500 miles. Did find leaks on oil cooler hoses. Having O rings changed. There may be some seepage from the oil cooler on the block as well. What would be the tell tale signs if it was piston rings?
    RS44Frank/ 2007 Pearl Black RS4/ 2008 OEM+ Pearl Black RS4
    Aug 17 2020
    Oshawa / Ontario / Canada
    What si considered normal oil consumotion?
    I am at 184K miles now and I add about 3/4 of a quart every 2400-2500 miles. So it falls in between my 5k change interval.
    My car is at 173KM and needs 3/4 of a quart added every 3000KM, although I have had oil cooler o-ring slow leak for a while now. Working on getting those done soon
    Veteran Member Four Rings Gewaltakt's Avatar
    Nov 01 2007
    06’ B7 RS4 Avant; Defender 110 safari truck
    Stuttgart
    It is part of this engines architecture that the piston rings leak until it is warmed up. Audi was cheap in choosing the ring supplier and this is the result, so some oil consumption is normal and I forget exactly how much.
    Other places to check for oil leaking. The vally under the intake manifold, the PCV, and into the coolant system. I suspect it is leaking from the oil filter housing and pooling massivly in the valley as well from the cam girdle possibly down the sides and burning off on the exhaust. None of those are easy to see unless you really get down into the engine bay with a mirror and a light.
    As well as was said above, if you pull the engine to change XYZ.. then beware it is a slippery slope. Trust me I am still falling down that one.
    Veteran Member Three Rings ginch's Avatar
    Jun 30 2011
    calgary, alberta
    Do you guys wait until the low oil light comes on or top up before that happens? I have yet to have a low oil light come on once in the 5 years I've had my current RS4 (141,000 km's). I change the oil every 6,000 km's.
    2008 Avus silver RS4
    1996 993 C4S
    2017 Tacoma TRD Sport, Quadcab shorty, 6 speed, Wife's daily!
    Gone
    2016 Reflex silver Golf R, 6 speed
    2008 Phantom black RS4
    B7 S4 Avant
    1993 964 C2
    2004 Reflex silver .:R32
    Veteran Member Three Rings blubusdrvr's Avatar
    Mar 02 2015
    1970 LT1 Corvette, 2017 A4, 2001 996TT
    Maryland, United States
    Quote Originally Posted by ginch View Post
    Hell no! I check it every single time I fill it with gas. I carry a quart in the trunk and give it a few oz every here and there. I’m religious about it. Take care of these motors and they’ll last for you. Starving them of oil is probably one of the worst things for them.
    This is a good point to bring up for people who have just bought their first RS4. When I first bought at 160KM , I did a fresh oil change with Motul (Have heard Motul burns more then liqui-moly). I did not know mine would be an oil burner so after 3K the low oil light came on and I added about 3/4 quart if I remember right. The point here being that if you've recently bought one, do the blubusdrvr check with the oil dipstick frequently so it doesn't get too low. I don't know if getting to the oil minimum light can have serious impacts if you fill right away, but obviously don't let it get to this point. I check every 500Km now
    Quote Originally Posted by Gewaltakt View Post
    Do you have more info on the piston rings quality? I'm going to do a compression test soon. Once the engine is warmed up, are the rings robust if they pass compression test, or should they be changed as a mid-life item anyways, because they can maybe break, fail, score cylinder walls? Any experience people have had with ring failure or issues would be be appreciated. Any after market piston ring options that people have used in builds? I was recommended king rod bearings on this forum which I'm going to do this year. Hopefully this is not even an issue to be considered and the rings are good on these cars from factory.
    Oct 21 2018
    Houston, TX
    Just wanted to give you all an update on this thread. I replaced/did the following, and oil consumption issues seem to be gone. Went on a spirited drive on the 3 twisted sisters in Texas hill country w/ the Audi Club of Houston and light never came on. Would have been impossible to do prior to maintenance. See below:
    Was previously using Castrol 5w_40, switched to LiquiMoly Molygen 5w_40
    Replaced injectors, coils, spark plugs, HP and LP fuel sensor, and PCV.
    Did deflap, carbon cleaning.
    Fresh fluids and filters.
    Oct 16 2014
    Checking in on this. Still no oil consumption?
    Oct 21 2018
    Houston, TX
    Quote Originally Posted by b57 View Post
    Car is good. Took a long time for the low oil light to come on after driving pretty aggressively. I think we are good.
    ^^ How long did it take for it to come back? My car is currently non-functional, but when it was I would get the oil light every 3000km
    Oct 21 2018
    Houston, TX
    I'd say every 1500 miles give or take.
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    I will have something to add but not going to do it on my phone due to the way it acts on this site, I'll post something later on it.
