I can see why tons of Audi people seem to use the extraction method much more often than other vehicle makes. Audi engineered a very annoying under body cover that's partially plastic and partially felt type material. There were like 12 torx bit screws (2 different sizes), 2 13mm bolts, and 2 plastic torx clips. Insanely overkill for an under body cover but i got the thing off. Luckily the car is high just enough to drive it up on ramps. My car just hit the 20,000 mile mark.
I purchased a replaceable oil drain plug since it is plastic and goes with the theme of the plastic oil pan. I initially thought a plastic oil pan is insanity but realized the plastic plug design is ingenious, with no torque spec, only needs a flat head, and snaps when placed into position. Changing the oil filter was insanely simple after i purchased a 32mm socket at Lowe's. Clicked the new filter in place and changed the o-ring for the oil filter cap.
I filled up with Liqui Moly 0W-30. The only thing i found massively annoying is the digital oil level indicator in the car versus no dipstick. Had to get the car up to temp, which meant i had to drive it around for over 5 minutes, had to shut the car off and wait 2 minutes for it to read. I realized I was at the max line, so what is annoying is not knowing how far above max i was. So i took out 0.4L of oil and now my level is just above half way in the min/max range. I do know ECS Tuning sells a dipstick but unsure if the thing is perfectly designed for my car or not since it seems to be used across a variety of platforms.
Even though it is annoying taking the the 1000 bolts off for the undertray i know where all of them are and a stubby impact was able to zip them off quickly enough for me. I plan to drain the oil and get a new oil drain plug via the lifetime replacement policy via FCP Euro. Also plan to send the oil back as well so it only costs me $20 per oil change. Dont want to unload on that extractor tool and hope i got all the oil out. I recommend filling the car with 4.5 liters of oil and topping off after using the digital gage in the car. It claims the car takes 5.2 liters.
