Results 1 to 4 of 4
    Feb 23 2022
    Montenegro
    Oil service reset
    98 a4 b5 tried couple of times to reset service oil,i hold the odometer trip button,ignition on,clock adjustment pull and it gets ---- also i do the same for service insp but idk what should i do next..I turn off the ignition stays there,turn the engine on it stays pls help
    Послато са SM-G960F помоћу Тапатока
    Feb 27 2011
    Winnipeg
    depending on the vin of your car if its an early 98 I'm going to say you need vcds, 96 and 97 you needed vcds to reset those.
    Feb 23 2022
    Montenegro
    Quote Originally Posted by seanf86 View Post
    Mine friend reseted me service inspection a year ago with delphi diagnostic,but could not remove service oil with it..He has vcds but he says delphi one is better...
    Feb 26 2023
    Portland Oregon
    I have the Ross-Tech dongle and VCDS software and just reset the service indicator last weekend. 1999 A4 Quattro so I know that method works. In my experience, with many, many Audi's that is the only way.
