Normally I am not the type to post up problems without trying to figure it out. When I fix Audi's I prefer to work thru it with process of elimination first.
This problem I have been chasing for almost a month.
Whats happening is on deceleration, im logging misfires between 1600rpm and 2200 rpms. Almost no issue as idle, slight rumble.
Its hard to notice the issue with the music playing, on deceleration or cruise control climbing or leveling off its sorta like a stutter or shaking for a few seconds. Later I also noticed a random popping sound when the boost hits above 15psi but no loss of power on high boost or WOT. It could be knocking/detonation but maybe fuel exploding in the exhaust?
I swapped plugs, coils but misfires stay on cylinder 4. Replaced plugs with the colder 8 ngk iridium but the problem still occurs.
Starting to think injector 4 must be leaking and maybe the tune doesn't mind the extra fuel???
