Flickr Album for all STK related photos:
https://www.flickr.com/gp/197521097@N03/gMb91029TR
I’ve wanted a B5 S4 for many years and finally got my hands on one mid summer of 2021. This car just so happened to be on Craigslist when I was actually searching for a B6/B7 S4 and I’m thankful it was. Furthermore, I’ve been reading single turbo build threads and watching videos since 2014 so these ideas were in play for quite some time. I’ve been collecting single turbo related items during the last 3 months of 2022 and began my first engine removal a few weeks ago. Shout out to Justin Ballou and CIP GAS on YouTube for those very helpful videos. I love documenting the progress I make with projects in hopes that something I either did or figured out might help someone else who goes through the same issues in the future.
This conversion process is as basic as I can make it so there won’t be any high horsepower, built engines, powder coated valve covers or huge turbo with firewall cut out for fitment. This should be geared more towards installing a Project B5, XS Power or older 034 STK with the goal of simplifying and/or deleting anything that is unnecessary while making power in the Stage 3 area. How expensive/cheap people go with parts is up to them. My previous setup is Stage 3 with BW RS6 turbos running roughly 22-23psi.
I’ve been in communication with user Monty23 who supplied the 034 STK hotside and Precision 6062 turbo. Thank you again! He and so many of you have helped me along the way. I hope to return the favor in some way down the line. To kick things off, below is the build list along with items I intend to delete.
Build List:
-Stock BEL Long Block
-Early Style “Monster Plenum" Intake Manifold (Stock 2.7t Runners)
-A8 W12 76mm Throttle Body
-Reversed Valve Covers w/ Project B5 Oil Catch Can Kit
-2.8 Exhaust Manifolds
-034 Motorsports Single Turbo Kit Hot Side Piping (3.5” Downpipe) - Catless
-Exhaust – 3.5”-3” adapter
-Exhaust - Custom 3” Downpipe back w/ Vibrant Resonator/Muffler
-Precision 6062 Turbo (.82AR Hot Side)
-Tial MVR 44mm External Wastegate (16psi Spring)
-4” Vibrant Performance (2875) Custom 45 Degree Inlet Pipe Cut to Fit w/ 4" HPS Offset Coupler (HTSOC-400-BLK)
-AEM 4" DryFlow Air Filter (AEM 21-3059DK)
-Project B5 FMIC Kit (Piping = 2.5” Hot Side / 3” Cold Side)
-FMIC Size: (3"x11.5"x30") (2.5” Inlet/Outlet) (Bar & Plate Core Rated to 600hp)
-New NGK BKR7E Spark Plugs (.022 gap)
-3 Bar MAP Sensor
-PMAS HPX MAF Sensor (Blow Through)
-Tial Q 50mm BOV (Vent to Atmosphere)
-Stock N75 for boost control
-Bosch EV14 1000cc Injectors
-Walbro 450lph Fuel Pump
-Spec Stage 3 Clutch with Lightweight Flywheel (Capacity: 580 Torque at the Crank)
-Innovate Motorsports PSB-1 Dual Boost/Wideband A/F Ratio Gauge
-034 SAI Delete Kit
-Exhaust Gas Temp Sensors Deleted
-Secondary 02 Sensors Deleted
-N249 Valve Deleted
-Coolant After Run Pump & Switch Deleted
-Clutch Fan Delete (PB5 Electric Fan Kit Installed)
-N80 Valve Deleted
I have acquired just about all of the parts with the exception of the Project B5 FMIC kit. Nick is in the process of building that. The kit will come with all wrinkle black charge piping, black silicone couplers, water/meth bung for AEM kit (future install), 50mm BOV flange, MAP sensor flange, blow-thru HPX MAF sensor flange and correct coupler to fit the A8 W12 throttle body.
