Hi, guys, i got a problem with my xenon adjustment, i was trying to adjust them by vcds, and then with a screwdriver, but when i went to the module 55 - Xenon Range, Basic settings and changed to group 001 i got an intermittent error for Headlights not adjusted and i can't calibrate my headlight, when i press ON its doing nothing and show the error.
Before, I did a normal scan for DTC's which didn't show anything, it wasn't until I went to the the control module 55 - Xenon Range, Basic settings and changed to group 001. It threw the code and every time I try to clear it just comes back.
Below is the output from VCDS.
Address 55: Headlight Range Labels: 8P0-907-357.LBL
Control Module Part Number: 8P0 907 357 F
Component and/or Version: Dynamische LWR H01 0010
Software Coding: 0000012
Work Shop Code: WSC 06314 000 00000
VCID: 3D718FF66471A8AC33-8068
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 253448 km
Time Indication: 0
Date: 2023.01.17
Time: 09:30:14
