I waited quiet a bit before I question on the forum. I read many posts and watched bunch of youtube videos. I never owned an Audi before. I always worked on Honda. This is different ball game!
my vehicles is 2012 Audi Q5 Quadro S-line sports utility. I inherited it with 103 k miles. Noticeable problem was, I noticed oil leak under belly pan and the steering is hard. This is where I stared my research. At this point I have a strong reason to believe that is is Valve gasket covers leaking.
So, I ordered new gasket covers. Same time I saw a video of carbon cleaning so I removed intake manifold to attempt Cleaning intake runner and Valve surfaces. This is where I am surprised. Almost all the video I have watched about 3.2 FSI engine, they all had Flaps in Lower intake runners and Separator just above the valve. My car has none of those. Which good, because I don't have to worry about installing flaps wrong!
Unfortunately, One of the valve cover bolt snapped (due to over toruqe) Probably me.
SHOULD VALVE COVER BOLTS BE REPLACED?
I am up to a point where I can pull injectors out and attempt to clean them. Currently injectors are still in the engine. Luckily none of the injector pulled out.
SHOULD I PULL INJECTOR AND CLEAN THEM? I already order injector seal kits and required tools to reseal them.
When timing chain covers leak, do they leak oil on top at all?
I am sorry for bombarding the questions. Please reply. Also please recommend any decent aftermarket parts I can use without worrying as Audi dealer is charging me arms and legs here.
Lastly,
IS IT WORTH INVESTING IN THIS Q5 AT THIS MILAGE? HOW LONG THESE ENGINE LASTS?
Any response would be appreciated. Thanks in advance guys.
T.
