Page 1 of 3 123 LastLast
Results 1 to 40 of 86
    Jan 16 2023
    Front brake pad options?
    Hi all, I purchased the 10-piston Akebono front brake kit with 420mm iron rotors, going onto my Volvo V90. It’s the same setup as the non-carbon-ceramic C8 RS6 & RS7. The kit comes with its own semi-metallic brake pads, but I’m planning for replacement options.
    Are there any replacement ceramic pads available for the iron brakes? Found another post from 2021 that said no options were out yet.
    The oem Audi pads with their obscene price tag are the typical dusty semi-metallic type. I see Dynamic Friction has pads in their 3000 semi metallic and 5000 “advanced low metallic” but I haven’t found a ceramic type pad, like available for all other applications.
    What are the C8 RS6/7 owners with iron brakes doing for pad jobs when it’s time? Just let the dealer throw on oem pads?
    Aug 15 2021
    Lawrence, KS
    There’s still no aftermarket. I have a request in with Gloc to see if they can make something.
    Aug 28 2020
    NoVA
    Last year I had Hawk and EBC both tell me we'd see something from them by the end of 2022. Still waiting. I'll need pads and rotors by early Summer so I'm still looking.
    Sep 07 2020
    Bellevue WA
    Quote Originally Posted by F10TT View Post
    I also reached out to Girodisc and they’re short answer was the tooling alone would be close to $30k to build the molds for brake kit options (rotors, pads) and he didn’t see the potential market opportunity for the C8 platform to justify their investment.
    Jan 16 2023
    Sigh, that’s a bummer to hear. EBC Hawk and Girodisc, they would just be semi metallic compounds anyway though? I’d have hoped a Powerstop Z23 ceramic or equivalent would have been offered for the C8 brakes by now.
    Economies of platform opportunity, Dynamic Friction offers not 1 but 2 pad type options for the C8, and cheap from rockauto, they just happen to both be semi-metallic formulations, or whatever “advanced low metallic” means. Listed under Urus, Taycan, and RS6.
    Cheers for the help, I’ll reach out to other vendors that offer these 10-piston kits and post back here with what else I see out there.
    Dec 02 2020
    Tampa Bay
    Quote Originally Posted by romanster View Post
    Out of curiosity, why?
    23 Cayenne GTS
    21 Daytona Grey RS6 (gone)
    12 Cayman R (PCA GTB1 club racer)
    Junior Member Two Rings
    Oct 10 2022
    Midwest
    I would be all in on some lower dust pads. I wouldn't care if they charged double what they do for their higher volume car platform pads.
    I've had awesome experience with PowerStop - as good or better than stock on the street and virtually no dust. this isn't a platform that I would take to the track, but if I did, I imagine I'd probably need different pads for that anyway to avoid the dreaded pad deposits (done that too many times on stock brakes).
    Jan 16 2023
    Quote Originally Posted by DeputyDog95 View Post
    Because.
    Tinkering is fun, and having giant yellow bananas behind the wheels lets others know your car is better than theirs. I already have a CTS-V 6pot 380mm yellow Brembo kit on the V90, but having seen all the 10piston kits, there’s no going back. These things dwarf every other brake set up out there.
    Kits like these are transferrable, swapping the caliper bracket and rotor hat will make it fit any vehicle, so it’s pretty future proof after the initial investment. Keep all the original brake parts to return to stock when the time comes to sell.
    The Powerstop ceramic pads are excellent, especially how clean they keep. OEMs still like speccing semi-metallic pads because having bite-y grabby brakes impresses the normies during test drives.
    Dec 02 2020
    Tampa Bay
    Because.
    No issues with your ABS or brake bias? I would think it would be freaking your ECU out.
    23 Cayenne GTS
    Jan 16 2023
    The math adds up from a piston fluid displacement aspect, these 10 smaller pistons end up right where even the basic 1 piston sliding calipers are pushing.
    The next issue would be torque bias as the front rotor size increases, it can feel a bit nose heavy when really hammering it, but cars are smart enough to deal with it before it becomes a risk of breaking the rear tires loose.
    That’s when only doing the front kits, they do sell rear kits to even things out, for cars like ours with electronic parking brakes, they are dual caliper read setups with dedicated EPB calipers, like the Tesla S, and R8. My rear kit has a 4pot Brembo Caliper and Tesla EPB caliper, on a 380mm rotor.
    How does Audi still spec old-timey single piston sliding calipers on these six-figure vehicles? Spec’ing monoblock calipers would be trivial, but sure would improve the looks.
    Dec 02 2020
    Tampa Bay
    Interesting. I club race a Cayman R on Pirelli slicks with stock calipers and stock sized rotors/pad, and even that small change drives the ABS wild and constantly results in "ice mode" under heavy deep braking. It's actually terrifying at times when the pedal goes hard but your car doesn't slow down. I would switch to a motosports ABS, but my car is a PDK and it won't interface.
    23 Cayenne GTS
    Jan 16 2023
    That does sound scary. Almost like the traction control system is overly sensitive to changes in wheel rotation. I can’t imagine you’d be losing traction with track slicks when hammering the brakes, but if the rear is unweighted enough to register a different rotation rate than the front wheels, the ABS could interpret that as traction loss and compensate by pulsing the pump.
    Any difference when disabling traction control and stability control? I thought there were track modes to turn off the nannies, since they can get in the way sometimes.
    Dec 02 2020
    Tampa Bay
    That's the only way I run it. TC and SC are always off, sport mode + always engaged. It's the ABS... The guys running manuals switch to motorsports ABS and the problem disappears, so it's 100% the computer being overwhelmed by the slicks under racing conditions. Sucks...
    23 Cayenne GTS
    Aug 15 2021
    Lawrence, KS
    i see nothing on rock auto listed for brake pads on a 22 RS6. where are you finding this?
    Jan 16 2023
    Look for them under
    21 RS6
    21 Lambo Urus
    21 Taycan, Panamera V8, Cayenne V8
    The Porsches even show pad options for the carbon ceramic rotors.
    Aug 15 2021
    Lawrence, KS
    Look for them under
    21 RS6
    21 Lambo Urus
    According to that entry those pads only work for cars that were produced prior to July 6th 2020, which indicates they may have changed the caliper design after that. It oddly does not mention the RS7 either which should have the same brakes.
    Jan 16 2023
    Saw that too, don’t understand why, but not worried. Was the C8 RS6/7 offered prior to 7/6/2020?
    The oem Audi pad number gets superseded a bunch of times on the Audi parts site, eventually to a single active number that covers all the C8 RS6/7 model years anyway.
    Pads for iron rotor 420x40mm
    4M8698151D
    Supercessions:
    4M8698151C
    4M8698151
    Fits between 2020 and 2022
    -RS6 to 7/6/2020
    -RS6 7/6/2020 to 5/31/2021
    -RS6 from 5/31/2021
    Like, what? Just say it fits all.
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    Not in stock. Curious as to how much cheaper the pads are vs what Audi is charging for them...I surmise the different will be astrofuckinomical.
    Jan 16 2023
    Hmm they delisted the Dynamic Friction pads from the RS6 and RSQ8 section, only leaving the out of stock Centrics.
    They’re still up under the Porsches and Lamborghini I mentioned above.
    The oem pad price is absolutely bonkers.
    Mar 05 2020
    Chicago Metro
    Bumping this to see if anyone has seen pads and or rotors for the C8. Still seems to be tumbleweed city.
    Veteran Member Four Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    I ran into these:
    https://racingbrake.com/pd1899-391/
    https://racingbrake.com/-pd1547-391/
    I've heard of the brand but don't have any direct experience.
    I reached out to Carbotech and they haven't gotten back to me yet.
    Current: 2022 Audi RS6 | Ultra Blue | 034 Lowering Links | 034 Resonator Delete
    Old: 2017 Chevrolet Corvette Z06 (Z07) | Blade Silver
    Older: 2013 Audi RS5 | Sepang Blue | Eurocode Alu Kreuz | 034 Transmission & Rear Diff Mount | Apikol Diff Mount | Girodisc 380mm Rotors | H&R RSS+ | SPC Upper Control Arms | H&R sways | AWE Track Extreme exhaust
    Olderer: 2011 Audi B8 S4 | Ice Silver | DSG | Sport Diff | APR 93 stage II+ V2
    Aug 15 2021
    Lawrence, KS
    Quote Originally Posted by PsYkHoTiK View Post
    I ran into these:
    Gloc (uses same compounds as carbotech & is a spin-off company due to a dispute) says they’ll make them. Try contacting them.
    Dec 02 2020
    Tampa Bay
    Bump to see if there is any new info...
    I am at about 27k miles.
    Pads are down to 5mm and the front rotors (steel) are developing a lip.
    The dealer quoted around $4k ish (parts and labor) to replace the pads and rotors. That seems a little excessive for brakes (most of it was parts).
    Are there any aftermarket options for pads and rotors yet?
    23 Cayenne GTS
    Nov 26 2006
    Memphis, TN
    I have seen some aftermarket steel to ceramic conversions (includes pads and rotors), but no direct replacement for steels.
    With some digging, EBC shows part numbers for replacement pads on their website, but I cannot find them actually for sale anywhere. Maybe a call to an EBC distributor could lead you in the right direction. I had to do UK/EU for the country. If I selected “US” nothing came up. For the rear pads, nothing came up for the RS6, but something did come up for the RS Q8. Both of these vehicles use the same factory part number for rear brakes, so aftermarket pads should be cross compatible.
    YellowStuff Front Pad: Part Number DP42492R
    YellowStuff Rear Pad: Part Number DP42456R
    I have never used YellowStuff before, but it is their high performance street pad. I have used RedStuff (their low dust pads) on other cars and been happy with EBC.
    ‘22 Nardo RS6 Wagon
    Apr 13 2012
    San Diego
    Quote Originally Posted by OneFastBMW View Post
    I used the yellows on my charger and they were great. Better stopping and less dust. Not same as the red for less dust but better than the stocks.
    2021 RS6 Avant - Navarra Blue with Xpel Stealth, Vossen S17-06 in Dark smoke, lowered 25mm, Milltek exhaust
    Dec 02 2020
    Tampa Bay
    I can't believe after 3 years, we don't have aftermarket options for steel rotors and brake pads.
    Do the RSQ8 share the same front and rear rotors as the RS6?
    23 Cayenne GTS
    Junior Member One Ring
    Aug 22 2022
    Valencia
    I’m new to the forum. I just wanted to see if anyone found any new info on aftermarket pads/rotors? I came across these RS7 pads:
    https://shop.redline360.com/products...yABEgLVsPD_BwE
    Do you guys think they will fit? I’m not in need of pads yet, but when it comes I’d like to be better prepare. Racing Brakes CCB conversion sounds tempting, but I’m not sure if those are available yet.
    May 05 2011
    QUeens/NY
    wow, would like to know if fit RSQ8 as well
    Aug 22 2022
    Valencia
    Here’s another option I found. Does anyone have experience with MTM? It looks like an iron to CCB conversion.
    https://www.mtm-usa.com/products/car...39609003343985
    Dec 02 2020
    Tampa Bay
    A couple of months ago, I brought mine in for the 37th recall... They said it needed new pads and rotors. I said, "How much?" They said around $5500 with tax, blah blah, blah. And you need new tires. I didn't do either repair and sold it back to them for a nice profit LoL I'm shocked at how expensive steel rotors and pads are for the Avant. Especially after tracking a GT3 for years and club racing a Cayman R. Those brake jobs are cheap by comparison!
    23 Cayenne GTS
    Nov 26 2006
    Memphis, TN
    Quote Originally Posted by MocoLoco View Post
    I would not touch anything from MTM-USA with a 100 ft pole. Too many stories of people like me who purchased something, never shipped, after months of asking for a refund, they finally went radio silent on me. I had to get AmEx to do a chargeback.
    ‘22 Nardo RS6 Wagon
    Mar 14 2021
    N New Jersey
    Yup ordered air intake from MTM florida and they never sent it
    after waiting 6 months i did charge back as well
    horrible customer service
    Oct 10 2019
    Toronto, Ontario
    Looks like EBC offers a full line of Front and Rear pads for the RS6 now.
    https://ebcbrakes.com/vehicle/usa/AUDI/RS6/
    Nov 26 2006
    Memphis, TN
    Finally!!
    I have had RedStuff brakes on many vehicles in the past and recommend them.
    ‘22 Nardo RS6 Wagon
    May 05 2011
    QUeens/NY
    it's about time but we can't get it anywhere, just googled the parts and nothing found!
    Oct 10 2019
    Toronto, Ontario
    I emailed them directly and my local EBC retailer as well to see if they have it in stock. At least there's a part number, which means it's "on the way".
    Aug 15 2021
    Lawrence, KS
    Reds would be a great upgrade for sure. Hopefully someone can find a place that stocks them soon.
    May 05 2011
    QUeens/NY
    tried to search those part numbers, still nothing on google yet.
    Oct 10 2019
    Toronto, Ontario
    Anyone see any aftermarket options for the brake pads? My light came on after 20,000 miles.
    Sep 29 2008
    Perhaps try Pacific German, sponsor here. They seem to be in the know with this platform.
