Results 1 to 32 of 32
    Senior Member Two Rings REDa3STALLION's Avatar
    Jul 22 2021
    Orange County California
    Tune recommendations
    Any recommendations on a stage 1 tune on my 1.8 2015 audi a3 ? IE ? UTRONIC? GIAC? And which tune the dsg,ecu or tcu? I almost ordered the ie and utronic and one said do I want to add the dsg tune with whatever tune it was so which tune to start out with ...reasonable price
    Sent from my SM-S908U using Audizine Forum mobile app
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Can't miss with any of big name tuners like the ones mentioned.
    Thanking ahead about what other mods you might do down the road is important because each have their own upgrade path.
    Bedsides that, go with whichever gives you the warm and fuzzies.
    I went with Eurodyne because you get all the files (stage 1, 2, and 3) at once, and I already had the flashing cable.
    2019 SQ5 Prestige
    Junior Member Two Rings
    May 25 2014
    Boston, MA
    Cobb AccessPort with EQTuning - by far the best solution and once you have the AccessPort you have access to a lot of different tuners.
    Junior Member Two Rings JepoyA3's Avatar
    Jul 18 2019
    I also went with EQTuning stage 1 via Cobb AccessPort. The EQT dsg tune is REALLY good but I also enjoy flashing to the Cobb OEM+ dsg tune for road trips because it's a bit more efficient with the mpg.
    Dec 27 2020
    California
    Quote Originally Posted by REDa3STALLION View Post
    I have been happy with my APR hi torque/DSG stage 1. I needed a CARB accepted tune, and APR for my car does this.
    Jul 22 2021
    I went qhead and got the IE tune what do you guys think about that one ?
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Since you're in Comifornia, is the IE tune CARB approved? I'm only aware of 2 tuners that are currently CARB approved - APR and COBB (and therefore, extending to their pro-tuners, ie. EQT)
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    IE stage 1 Blew my motor. Its a long saga. PM me.
    They mess with emissions and dont tell you... they get their power because they pull back the safety measures for knock. These motors are especially susceptible to LSPI (Low Speed Pre Ignition) which is what blew the piston apart on humble mechanic's youtube Q3 motor. When you pull the safeties back for Knock on a motor that is very fuel and knock sensitive... it ends poorly. I have switched to APR and will only use Motul in the motor going forward.
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Jul 22 2021
    So do I send back the tune and get apr or what this is my car online which jeopardizes my life if without right so anymore feedback on IE tune stage 1 and is there anything I need to upgrade or what not before tuning ? I have intake res delete muffler delete inlet pipe turbo muffler delete and also do I take my jb4 out ?
    Dec 14 2021
    Flash at your nearest AUDI dealer. Whether it’s APR or Uni you’ll be in good hands. Make sure you get the DSG tune, it sucks to fork out the extra money but you need it. Sounds like you have too much of a learning curve to really mess with something like flashing yourself and choosing or tweaking tune files like with Cobb for example. GOAPR
    Any hesitancy you have about getting tuned will disappear as soon as you hear the new engine note with your motor tuned when it fires up. The unwritten deal is that if you flash at a dealership they will usually be cool about warranty repairs instead of just pointing to the tune to absolve themselves of liability or warranty work
    Dec 14 2021
    You can keep your JB4 installed as it is a “piggy back” module but I don’t think it can do anything the acesssport can’t; like program launch control/ boost by gear ect. IE is good, you’ll be a happy camper and the COBB/EQT is the best way to tune if you plan to continue modifying your car
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Yes you can return the pos IE tune, yes remove JB4, if you want to tune from home that would be Uni and GIAC, APR is a dealer visit, and as stated above get the matching DSG tune.
    Stage 1 more than you RS3
    Jul 22 2021
    Quote Originally Posted by S3DAN View Post
    First of all I'm not under warranty second is you sound like you work for apr haha but I understand everything your putting out and apr is a good company and to be honest I think tuning it may just increase my odds at another speeding ticket as I just got out of one going 109mph (cost me 500 for lawyer) and another going 75 in a 55 zone bs but dropped and honest I have a few things like tires radiator and a rad fan to get before even tuning but I can't send back the tune yet cuz it gets here today so we will see what I end up choosing but just wanted some feedback to help me decide
    Jul 21 2013
    B6
    I have eqt stage 1 ecu/tcu and am very happy with the setup on my ‘18 a3. Bought the accessport used so I’m into it for 1k total.
    2004 A4 USP 3.0 6MT | 2002 Allroad 2.7t | 2018 A3 daily
    @b6_ultrasport
    Jul 22 2021
    OK so I tuned the audi and I feel it's too much power for the car and not only that it's gone into limp mode twice now where I had to pull over and restart the car the first time check engine light came on and wen I scanned it with ob11 a misfire popped up and a cylinder issue idk but any feedback ?
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Something clearly wrong. What tune did you put on it? Maybe best to remove it altogether.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Jun 24 2018
    IL
    Is your tune for the right vehicle? I remember you saying before you have the FWD 1.8T as opposed to the the 2.0T. Check spark plugs? I would take it to a performance/aftermarket shop who can diagnose it.
    2018 RS3 Daytona Gray
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Perspective: Cobb's tunes that they provide with the AP do not alter the knock retard or sensor tables at all. People regularly complain that Cobb's tunes suck because they have high timing retard numbers. If you increase boost and timing to get more power and don't alter the stock tables of course timing will be retarded more. It's implausible that tuners aren't modifying the stock tables if they are increasing boost and timing.
    Jul 22 2021
    So I was thinking spark plugs too, let me try that and see what happens, any recommendations on which spark plugs ?
    Jul 22 2021
    OK so I was in sport mode and flored the gas and it was going good for a minute then all the sudden lost power almost in limp mode basically limp mode and check engine light came on and I had to clear code to get it running normal again
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Prediction: You'll be posting about a blown motor soon. You can't just clear codes and its all good. Something is seriously wrong.
    Jul 22 2021
    So flash back to stock and see if I have the same issue ?
    Jul 22 2021
    OK so I read the codes thru the ie tuner and the only one that came up was mass air flow sensor or volume air flow sensor but I flashed car back to stock and that's only code came up. Haven't driven it yet but will soon within hour
    Dec 25 2004
    Earth
    Quote Originally Posted by Spinnetti View Post
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Apr 01 2007
    houston texas
    Step one - fix all known issues with the car. MAINTENANCE BEFORE MODS!
    Step two - confirm the car is operating 100% and maintenance is up to date.
    Step three - add mods.
    If you do these out of order you will find yourself chasing small issues here and there perpetually, and never enjoying the car at its true performance peak.
    2019 SQ5 Prestige
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by MikTip View Post
    ...and it could end with a fiery stallion lolz
    https://www.audizine.com/forum/showt...light=stallion
    Jul 22 2021
    Quote Originally Posted by 949 View Post
    You don't have anything else better to do then re post someone else's posts talking shit, now if you ask me you have way too much time on your hands and or you a dorky ass douche obsessed with someone else's faults or life but only you have to live with yourself so .....oh well
    Nov 27 2020
    Florida
    Make sure you took the jb4 off if you tuned it. I'm not sure you got good advice about that. Definitely one or the other.
    Jul 22 2021
    Jb4 completely uninstalled
    Dec 14 2021
    You need coil packs. Buy OEM Eldor brand coil packs. Do not buy any 3rd party brands of coil packs. Change them and you will avoid being stranded with blown coil packs. These fail 100% of the time after being tuned in my experience and I have never had good experience with any other brand coils except OEM and specifically the Turkish made eldor brand. I don’t work for APR, I am a customer, but not a big fan truthfully since I will have to switch brands to go to stage 2 anyways after they pulled that discontinuation of stage 2 tunes stunt.
    Jul 22 2021
    I got mine on Amazon and was a brand called A-premium
    Jul 22 2021
    So not sure what this issue is but I fixed the coils and spark plugs but I think the coils that were bought on Amazon are the reason behind my troubles. I thought the ones I bought were the original ones / stock ones (which the brand is A-premium) bought come to find out there not and the ones I'm looking for that are stock are about $60 each so I guess until I have the funds to get those, we will just have to see if that's the issue bcuz just now on the way to lunch I punched it and the check engine light came.on and it started hesitating to go/accelerate and I scanned the car and misfires fault codes were popping up
