Hey guys...
I've got what sounds like trouble with a new ac compressor. Watch/listen here: https://youtube.com/shorts/Xaw_oIUOXYs?feature=share
I just got finished replacing the ac compressor and condenser on my 2010 Q5 3.2. The original compressor belt pulley broke so I pulled it and the condenser, flushed the evaporator and just got it all back together.
The compressor was from RockAuto and is the UAC model they had for my car. It came precharged with 5.7 oz of oil.
My process was this:
After removing parts, I used ac flush to clean the evaporator via high pressure line.
Ran compressed air via air compressor through high pressure line till almost nothing came out. (was very clean)
Upon opening the compressor box, I set it up vertically for a few minutes and then spun the pully clockwise 10x like I saw recommended. Then repeated it a few more times just to be sure the shaft seal was lubed.
Next, hoses were attached and it was mounted back on the block.
New condenser was installed w/ drier already installed.
All ac connections were made and then put the rest of the front end back together.
Pulled vacuum for approx 2 hours and then let sit for an hour to check for leaks. No leaks...
(I was going to wait till this weekend to put R134 in due to current weather and wanting to do it during the daylight.)
I started it up after putting the serpentine belt back on and it all sounded fine till I took it out of the driveway and it hit close to 2000 rpm's. That's when I first heard the noise.
Slowed down and sped up a little and it kept happening and didn't change so turned around and drove under 15 mph back to driveway.
Could I have a bad replacement compressor?
Does anything sounds wrong about my flush/install?
I saw another video that made it sound like you spine the compressor about 10-20x before pulling vacuum or charging the system to prevent hydrolock of the oil in the compressor. Could that be the issue? I hadn't spun it once installed, prior to pulling vacuum.
Could it be that I haven't added the R134 to the system?
Or any other thoughts on what I might be missing?
I really want my car back!!!
Thank you!
