I’ve been getting some questions on FB and the forums on what is needed to do a Cerwin Vega Spare Tire Subwoofer install. Below is most of everything you’ll need to do the install including the Powered LOC which is only needed if you have the B&O Sound System.
You need the Powered LOC because not all amps will work on a B&O system. If the amp can’t see 40v on the speaker input, your B&O amp will cut out because it will short to ground after a some of start cycles. This is why I’m recommending the Powered LOC below. I’m recommending the AudioControl LC2i because this Powered LOC is a direct plug and play to my Harness I listed below.
Here are the items you will need.
-Cerwin Vega Spare Tire Sub(VPSTX12 Slim Model) - https://amzn.to/3VLtBy0
OR
-Diamond Audio DASTX12 - https://amzn.to/41YFxAd
-24” with Block Connector Plug and Play Harness - https://tinyurl.com/4vtawdt5
-Kicker PK8 8 Gauge OFC Power Kit - https://amzn.to/3jUYq5g
In addition to the above, the below is needed if you have the B&O Sound System.
-AudioControl LC2i Pro - https://amzn.to/3WDS8Gz
-Inline Fuse Holder - https://amzn.to/3OIichv
-2 Amp Fuses - https://amzn.to/3qf3OU5
-Wire Tap - https://amzn.to/3Xtzh00 Don’t order this if your buy my harness. I send you 1
-16 gauge power and ground wire for LC2i - https://amzn.to/437jqap
Assorted Connectors - https://amzn.to/41Pzez3
-RCA Cable - https://amzn.to/2XbO7Lp
Below are a couple of pictures you can use as reference points for the power and ground wire connection. This install is pretty straightforward. The battery and ground are the hardest connections to make and even then it’s not very difficult. You don’t need the remote wire if you have a Non B&O Sound System and are using speaker level inputs.
-Positive connection to battery. You will just undo that torx screw to secure the kicker power cable. Make this connection after you’ve build your power wire to length with the fuse block inline and the fuse not attached. Inserting the fuse will be the last step of this project.
The ground can attach here.
The AudioControl LC2i Powered LOC does require a power source. You need an inline 2 Amp Fuse. Above I’ve listed an inline fuse to use. You can connect this directly to the battery or tie into the power connection you made to the sub. In both cases, use the inline fuse off of the power source. Route the ground wire to the same source as the sub.
AudioControl LC2i Powered LOC doesn’t require a remote turn on wire as your can use signal sensing(which I don’t recommend). To run a remote turn on here is the process. You will need to tap into the 12v plug on the right side cubby. This is really simple. All you’ll need to do is pull the cubby out and disconnect the connector from plug. Go about 10 inches back from the connector and peel away the tape. Find the white or yellow wire to tap into. I’ve listed the wire tap you’ll need above. If you get one of my harnesses, I include a wire tap. The AudioControl LC2i Powered LOC has a Remote In and Remote Out. The the Remote In accepts the wire coming from the cubby and Remote Out goes to the Subwoofer.
Any question or if you need a harness feel free to email me @ [email protected].
