connected VCDS, the rear wiper shows up as inactive
when I push the switch forward it says active
when I push the sprayer on:
sprayer says active
wiper says inactive
Im assuming this is correct operation
following this TSB
https://testing-public.carmd.com/Tsb...107425/A921511
with wiper switch pushed forward to activate rear wiper I read the following values
I get 11.32 volts between pins 1 and 4
I get 6.5 volts between pins 4 and 3
I get 11.32 volts between pins 4 and 2
voltage difference was more than 0.5 volts between pins 4/3 and 4/2
according to TSB I may have a broken wire?
then I noticed that the wiper had wiped he glass, it started working momentarily. then stopped again
I then jumped pins 1 and 2 and the motor works.
so I narrowed out the motor being bad and believe the switch also to be ok.
for fact that the wiper worked for a moment I thought the break in the wire must be in the rear hatch opening. I pulled the trim and undid the harness black sticky cloth and saw no broken wires, I went as far as I could see into the roof following the harness, nothing broken. I did not proceed into the wiring going down the side of the hatch, cannot imagine wire breaking down there, it all stays pretty still.
I did not check the harness as the TSB states to do in the driver door opening, guess that will be my next inspection.
I just don't get why it started working for a minute
