My PCV valve failed, it had a tear in the diaphragm. I took it apart and confirmed that. With the torn PCV valve there was of course plenty of negative pressure on the oil cap with the engine running.
New PCV is installed, now I have a very slight amount of positive pressure on the oil cap. If I put my hand over the oil cap hole and then move my hand away with the engine running there's a very slight amount of pressure release. It doesn't seem to build up to any extent if I keep my hand there for 30 seconds or so, it's the same after 2 seconds as it is after 30
2002 3.0
Canyone else with this engine confirm what they're seeing on the oil cap?
