I’m building new pigtails with 2.2ohm resistors to plug into the factory airbag connector since I replaced my factory seats with a set of BRAUM fixed back seats.
I depinned one of the factory connectors on the seat side to double check the resistance value. (Confirmed in my 2010 S line with Alcantara seats it is 2.2ohm)
I had thought I needed the following repair wire kit for the replacement connectors (000-979-034-EA)
But, now after deppining one of the factory connectors, I can see it should have a thin flat pin extending at the end of the connector like this.
Can anyone help to identify what the correct repair wire kit from VW/Audi is?
I want to get rid of the airbag error in the dash.
Thanks!!
