Results 1 to 19 of 19
    Junior Member Two Rings lteeuro's Avatar
    Nov 22 2021
    Pennsylvania
    O-rings for 3.0 tfsi timing cover
    Hey guys, in the middle of doing a full timing service on my A6 and realized I don't have the three o-rings that seal the oil passages from the block that dead head on the main timing cover. Researched it extensively and can't pull up part numbers. Any help?
    Sent from my Pixel 6 using Audizine Forum mobile app
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Go see your dealer tomorrow, they will be able to find the parts and possibly have them in stock. Change the rear main seal while you are at it, not that expensive. Make sure you have a decent bead of sealant on the covers when you put it all back together.
    Amazon has a really nice nylon bristle brush set that will make short order of cleaning all the gasket surfaces.
    Nov 22 2021
    Pennsylvania
    10-4 thankx. An yup I got a main seal with the kit
    Nov 22 2021
    Pennsylvania
    Update...the dealer can't seem to find them on a diagram. I'm at a loss as to where to look if Audi themselves can't find them.
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by lteeuro View Post
    Can you post a picture of where they go? I have ETKA access. What engine code do you have or at least model year?
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Nov 27 2018
    Valparaiso, IN
    Make sure you have a set of “long” triple squares if you don’t already. I had bought the short stubby set first and found out they are too short for the cam bolts. I bought a 4 inch set off Amazon
    Nov 27 2018
    Valparaiso, IN
    ECS or FCP might be able to help. I bought my kit from ECS but some of the extras from FCP
    Nov 22 2021
    Pennsylvania
    Nov 22 2021
    Pennsylvania
    Nov 22 2021
    Pennsylvania
    Quote Originally Posted by Valpo A7 View Post
    Gotcha. I got my kit from FCP but neither company seems to have those o-rings. Unless I just don't know where to look
    May 26 2015
    Mormon Country
    They appear to be #25 and #26. I would confirm that though.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Nov 27 2018
    Valparaiso, IN
    Talk with an order rep at those stores. The big ticket items you can usually find easily on the site but it’s best to call for the needle in the haystack
    Nov 22 2021
    Pennsylvania
    Quote Originally Posted by GilliamOS View Post
    Thankx for the help there... unfortunately on my end the part numbers are too fuzzy for me to read them. Could you send those two numbers over?...be appreciated.
    Nov 22 2021
    Pennsylvania
    I did call ECS...they couldn't find them. Haven't called FCP yet...
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Looks like:
    Engine Crankshaft Sealing Flange Gasket.
    Part Number: 06E103181K
    Supersession(s): 06E-103-181-K; 06E103181B; 6E103181K
    and:
    Part Number: 06E103181L
    Supersession(s): 06E-103-181-L; 06E103181C; 6E103181L
    Quantity for #25 (K) is 1, Quantity for #26 (L) is 2. Each one is listed as about $10.50 full retail at the Audi parts website. As GilliamOS wrote, you should confirm.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Nov 22 2021
    Pennsylvania
    Awesome. Thankx a million...found them
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    slightly off-topic - can anyone recommend a good tool set for this job available on amazon. it looks like my driver side t40133 might not fit correctly.
    Nov 27 2018
    Valparaiso, IN
    Quote Originally Posted by fastboatster View Post
    It’s not uncommon for driver side and passenger side to totally not lock down correctly. You have to lock 1 side then rotate forward or back slightly to line up the cam threaded holes. With chain stretch you could be slightly off. Understand the cams will lock at top and bottom dead center as well. The crank will rotate 1x for every 2x with the cams. The crank will be lined up when you see the divot in the crank in the hole the pin goes in.
    Apr 23 2019
    CA
    I get all of this, and my driver side was definitely off and I couldn’t line it up even by trying to turn the crank forward or backwards, I eventually even ended up breaking one bolt of the alignment tool. Passenger side lined up very easy, though. However, what also led me to believe my tool is bad is when I removed the driver side cam girdle and tried to align the cams in the girdle. The tool wasn’t parallel to the girdle at all after I tightened the two bolts (which I replaced with stronger ones) and the intake cam seemed to have its slit not being parallel to the girdle either. Anyways, another tool I got off the Amazon seems to be better, and things seems to line up well as tested on the extra cylinder head I have from my old engine.
