The code was P0016. The problem was corrected.
in the process of fixing this P0016 the VagCom came back with
2 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 002 - Incor. Correlation - MIL ON
16725 - Camshaft Position Sensor (G40)
P0341 - 008 - Implausible Signal - Intermittent - MIL ON
I tried to check the VagCom for Camshaft Adjustment (intake) Group 093 & 094 in order to see if maybe the chain was stretched but no signal came back.
I think it might be the (G40) wire broken. I intend to run wires directly as far as possible before the ECU, I want to run the wires (pinned straight to see if that could be the issue.
Looking for a wire diagram for the cam position sensor and really any input from the FORUM GENIUSES or ideas in order to get this done.
