Thank you both for your inputs. As it turned out, 000-915-105-CC is the actual part number for the H6 AGM battery. 000-915-105-CC-DSP is the number in their system that reference the 000-915-105-CC battery and that's the number that printed on your receipt...weird, I know.
Battery prices varies tremendously between dealers.
- The Audi dealer near my work wants $229 for the AGM battery as referenced above.
- The Audi dealer near my home wants $323 (part) + $375 installation & programming for the same battery - BIG NO. I then went across the street to the VW dealer and paid $216 for the same battery.
Other options I've looked into:
- Walmart H6 AGM - $170. I have one of their H8 AGM currently in my X5 and it's actually not a bad battery. Was going for this option, but it doesn't have an Ah rating, which was required for battery programming. If I had to, I can probably just use any numbers between 68Ah to 72Ah and probably be OK since it's the range for this size battery.
- Oreilly's H6 AGM - $240. Why bother when an OE can be had for less? Also doesn't have an Ah rating
- Autozone H6 AGM - $240. Why bother when an OE can be had for less? I had used their AGMs in my Z4MC and X5 in the past and didn't have good experience with it - wouldn't be my 1st choice.
Here's a picture of the new AGM vs the original EFB that came with the car. Since the OE EFB lasted more than 5.5 years, I would be pretty happy if the replacement can do the same.
