Results 1 to 9 of 9
    Senior Member Two Rings 9803audiboy905's Avatar
    Jun 17 2007
    07 A4 2.0TQ .. 03 A4 1.8TQ .. 06 R6 Raven
    Cranston, R.I,
    Replaced alternator and battery… Car still won’t start
    Yeah, about two weeks ago I was driving the car out of the road. After calling AAA and doing some diagnostic when I got home, I realized that the culprit was a bad alternator. I replaced the alternator yesterday as well as adding a new battery to the conversation the old one was passed his life expectancy. at this point, the car has juice but it does not want to turn over to start. It has fresh gas in her and also the plugs and coils aren’t that old. The noise I get when pushing the key in almost sounds like something is blocked. Any help on a next time even if somebody has had the same problems would be really appreciated. I tried searching, but came up pretty much empty-handed.
    Dec 29 2017
    Phoenix, AZ
    I'm not sure coding would stop the car from turning over, but just to rule it out... Did you code the battery to the car?
    Is the starter turning over? Are you using the key or start button?
    2010 Avant // 2015 Allroad
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    Coding the battery has nothing to do with it, but obviously you should check the fuses for the alternator.
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Jun 17 2007
    Cranston, R.I,
    No, I did not the battery to the car. The starter sounds like it’s turning over. I haven’t checked it with a meter yet. I know this is going to sound dumb as I don’t have the original. Owners manual. But which fuse box are the fuses for the alternator him. So far I have come across the one on the drivers door, the one on the passenger door and the one in the trunk on the right hand side. But have come up empty
    Jun 17 2007
    Cranston, R.I,
    Might also be worth noting that the car isn’t presently throwing any codes
    Jan 18 2022
    2015 A4 Prem. Plus, 1987 Scirocco 16V
    Raleigh, NC
    Have you tried turning the motor over by hand? It is very possible that your balance shafts have seized causing a no crank. If the engine turns over but does not start. Double check and make sure you have everything plugged in on the back of the alternator and that the grounds are good.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by StuckAntichris View Post
    this
    i have written about this at length...
    pull the plug so you ae not fighting compression , put the car in neutral and put a wrench on the crank .. it should turn over like butter...
    if you were driving along and all of a sudden it felt like you were losing power and it just stopped .. thats likely what it is .. if your alternator had dies and you were driving along on battery power your alternator light would have lit up like a christmas tree telling you it cant put ot 12v. If you didnt see this it is not the alternator or the battery ...
    If you try to start it and its seized there is a good chance you have burned out ( or could burn out) the starter.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jan 18 2022
    Raleigh, NC
    It was reading your posts about the balance shafts that led to my question. I hope the starter is fine at this point but it only took 1 crank when my motor grenaded to burn up my starter...
    Feb 15 2016
    Cambridge,Ontario
    yeah usually that braided wire from the solenoid to the starter cooks.
    1976 Yamaha XS 360
