Results 1 to 21 of 21
    Junior Member One Ring
    Dec 06 2022
    Sydney, NSW, Australia
    Driver door lost power after replacing the door speaker
    Hi
    I replaced the Driver side (Right hand drive) door speaker with OEM Speaker and when I put the door trim back on the drive side door had no power whatsoever, I ran the OBD11 output test on driver side windows and mirror and both worked apart from door lock and door lights, however, for some reason OBD11 automatically popped up the option to update the gateway which I pressed ok. since than I can not access door control unit, if I add the control unit manually and try to access it has error message "Control unit do not respond. Check the ignition and try again." I checked all the fuses, tested the loom with multimeter and also a visual check does not show any brake in the door harness. I tried a different control unit without any success, I disconnected the battery black cable over night but nothing works apart from the door speaker, after disconnecting the door loom I have a message "gearbox malfunction Audi you can drive in manual mode" now the gear lever is stuck in Park mode. Any help will be most appreciated.
    Below is the recent log from OBD11:
    OBDeleven data log
    Date: 2022-12-07 14:15
    VIN: WAUZZZ8F0CN013586
    Car: Audi S5 Cabrio
    Year: 2012
    Body type: Cabriolet
    Engine: CGWC 245 kW (333 HP) 3.0 l
    Mileage: 79740 KM
    01 Engine
    System description: 3.0l V6 TFSI
    Software number: 8K5907551B
    Software version: 0004
    Hardware number: 4H0907551
    Hardware version: H07
    ODX name: EV_ECM30TFS0218K5907551B
    ODX version: 002005
    Long coding: 1A250034052701020000
    Trouble codes:
    U019900 - Lost Communication With "Door Control Module A"
    static
    Date: 2022-11-28 18:27:30
    Mileage: 79749 km
    Priority: 6
    Malfunction frequency counter: 18
    Unlearning counter: 255
    Engine speed: 702.00 1/min
    Normed load value: 14.5 %
    Vehicle speed: 0 km/h
    Coolant temperature: 106 °C
    Intake air temperature: 83 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 12.695 V
    Dynamic environmental data: 209628117D2711DE0015AA00110E0214A66E15D200
    02 Transmission
    System description: 0B5 30TFSIRdW
    Software number: 8K1927156R
    Software version: 0007
    Hardware number: 0B5927156F
    Hardware version: H10
    Serial number: 0000000976
    ODX name: EV_TCMDL501
    ODX version: A02196
    Long coding: 000001
    Trouble codes:
    P189000 - Signal wire for Tiptronic Electrical error
    static
    Mileage: 79749 km
    Priority: 2
    Unlearning counter: 40
    Engine speed: 706 1/min
    Transmission input speed: 706 1/min
    Transmission output speed: 0 1/min
    Engine torque: 4 Nm
    Transmission fluid temperature: 89 °C
    Accelerator position: 0.0 %
    Clutch status: Beide Kupplungen offen
    Dynamic environmental data: 209628F442332C108106001082060208010000080266660803 000008046666
    P176100 - Interlock=>magnet Short circuit to ground
    static
    Mileage: 79749 km
    Priority: 2
    Malfunction frequency counter: 5
    Engine torque: 4 Nm
    Dynamic environmental data: 209628F442332C211301107A0010050000
    03 Brakes
    System description: ESP8 quattro
    Software number: 8K0907379CK
    Software version: 0100
    Hardware number: 8K0907379CK
    Hardware version: H09
    Serial number: --------------
    Long coding: 295D0C
    Trouble codes:
    01486 - System function test activated
    static
    Priority: 4
    Frequency counter: 3
    Driving cycle: 121
    Mileage: 79749 km
    Date: 2022-11-28 18:27:37
    01331 - Driver side door control module No signal/communication
    static
    Priority: 3
    Frequency counter: 11
    Driving cycle: 121
    Mileage: 79749 km
    04 Steering Angle Sensor
    Trouble codes:
    No trouble codes found
    05 Keyless System
    System description: BCM2 2.0
    Software number: 8K0907064FR
    Software version: 0602
    Hardware number: 8K0907064FR
    Long coding: 05B30F00000000000000
    Trouble codes:
    01330 - Comfort system central control module Please read DTC
    static
    Priority: 6
    Frequency counter: 2
    Driving cycle: 120
    Mileage: 79749 km
    Date: 2022-11-28 18:27:36
    03284 - Right access/start authorization antenna Open circuit
    Intermittent
    Priority: 2
    Driving cycle: 161
    Mileage: 79748 km
    Date: 2022-11-29 13:09:56
    06 Passenger Seat
    System description: MEM-BFS
    Software number: 8T0959760E
    Software version: 0076
    Hardware number: 8T0959760E
    Serial number: 00000026966222
    Long coding: 01237025002C00000000
    Trouble codes:
    08 Air Conditioning
    System description: KLIMA 3 ZONEN
    Software number: 8K2820043N
    Software version: 0036
    Hardware number: 8K2820043N
    Hardware version: H04
    Serial number: 01280320122239
    Long coding: 6627628000
    Trouble codes:
    00457 - Vehicle Electrical System Control Module Please read DTC
    static
    Priority: 6
    Driving cycle: 121
    Mileage: 79749 km
    Date: 2022-11-28 18:27:38
    static
    Priority: 6
    Driving cycle: 120
    Mileage: 79749 km
    09 Central Electrics
    System description: BCM1 1.0
    Software number: 8K0907063DJ
    Software version: 0103
    Hardware number: 8K0907063AJ
    Hardware version: H14
    Serial number: 00000027953401
    Long coding: 260000108034AFE0168140C300001D0D0F9D43882709020100 0008000401010200020064000000
    Subsystems:
    System description: WWS 020412
    Software number: 8F2955119
    Software version: 0021
    Hardware version: H06
    Serial number: SWF12040025215
    Long coding: 00FD11
    System description: G397_RLFS
    Software number: 8U0955559B
    Software version: 0002
    Serial number: 20224313
    Long coding: 02005D
    System description: E1 - LDS
    Software number: 8K0941531AS
    Software version: 0031
    Hardware version: H03
    Serial number: 00000000000204120273
    System description: AQ_Hum_Sensor
    Software number: 4H0907658
    Software version: 0003
    Serial number: B968C026000000000001
    Trouble codes:
    03608 - Humidity sensor in fresh air intake duct Faulty
    static
    Priority: 3
    Frequency counter: 10
    Driving cycle: 121
    Mileage: 79749 km
    Date: 2022-11-28 18:27:45
    0E Media Player
    System description: CDC-MP3-Pana
    Software number: 8X0035110C
    Software version: 0490
    Hardware number: 8X0035110
    Hardware version: H41
    Trouble codes:
    15 Airbag
    System description: AirbagVW-AU10
    Software number: 8F0959655D
    Software version: 0430
    Hardware number: 8F0959655D
    Hardware version: H12
    Serial number: 003KGD8062UC
    ODX name: EV_AirbaAU10SMEAU485
    ODX version: 001004
    Long coding: 30414135353130303030554A305238463053
    Trouble codes:
    16 Steering Column
    System description: Lenks.Modul
    Software number: 8K0953568L
    Hardware number: 8K0953568L
    Serial number: 90372LD3001WR
    Long coding: 000036
    Subsystems:
    System description: E221 - MFL
    Trouble codes:
    17 Dashboard
    System description: KOMBIINSTR.
    Software number: 8T0920930F
    Software version: 0540
    Hardware number: 8T0920930F
    Hardware version: H35
    Serial number: NSW53EF3D
    Long coding: B32719000B010008010000
    Trouble codes:
    19 Gateway
    System description: GW-BEM 4CAN-M
    Software number: 8R0907468C
    Software version: 0025
    Hardware number: 8R0907468C
    Serial number: 1441Y124040283
    Long coding: 00CF07FF00
    Subsystems:
    System description: J367-BDM
    Software number: 8X0915181
    Software version: 0141
    Serial number: 00000000003790754113
    System description: J532_DCDCStab
    Software number: 8K0959663B
    Software version: 0006
    Hardware version: H05
    Serial number: 12077000736011200410
    Trouble codes:
    Intermittent
    Priority: 2
    Frequency counter: 6
    Driving cycle: 161
    Mileage: 79749 km
    Date: 2022-11-28 18:29:13
    04014 - Control module for engine noise generation No signal/communication
    Intermittent
    Priority: 2
    Driving cycle: 160
    Mileage: 79749 km
    01303 - Telephone transceiver No signal/communication
    Intermittent
    Priority: 2
    Driving cycle: 160
    Mileage: 79749 km
    Date: 2022-11-28 18:30:55
    00384 - Optical data bus Open circuit
    Intermittent
    Priority: 5
    Driving cycle: 160
    Mileage: 79748 km
    Date: 2022-11-29 14:46:44
    01334 - Right rear door ctrl. module No signal/communication
    Intermittent
    Priority: 2
    Driving cycle: 161
    Mileage: 79748 km
    Date: 2022-12-06 13:49:35
    26 Roof Control
    System description: VSG-AUDI-B8
    Software number: 8F0959255
    Software version: 0190
    Hardware number: 8F0959255
    ODX name: EV_ElectRoofContr
    ODX version: 001008
    Long coding: 010000
    Trouble codes:
    U111100 - Function limitation due to missing message
    static
    Date: 2022-11-28 18:35:00
    Mileage: 79749 km
    Priority: 6
    Unlearning counter: 120
    static
    Date: 2022-11-28 18:27:42
    Mileage: 79749 km
    Priority: 6
    B119E01 - Supply voltage 1 for switch and sensors Electrical error
    Intermittent
    Date: 2022-11-28 00:00:25
    Mileage: 79748 km
    Priority: 2
    Unlearning counter: 161
    B119F01 - Supply voltage 2 for switch Electrical error
    Intermittent
    Mileage: 79748 km
    Priority: 2
    36 Driver Seat
    System description: MEM-FS
    Serial number: 00000026964852
    Long coding: 013B7B25002C00000000
    Trouble codes:
    static
    Priority: 6
    Driving cycle: 120
    Mileage: 79749 km
    Date: 2022-11-28 18:27:46
    03319 - Tilt adjustment switch, down mechanical malfunction
    Intermittent
    Priority: 4
    Driving cycle: 161
    Mileage: 79748 km
    Date: 2022-11-29 16:16:34
    44 Steering Assistance
    System description: RCEPS
    Software number: 8K0909144F
    Software version: 0507
    Hardware number: 8K0909144B
    Hardware version: H36
    Serial number: 0023461906
    ODX name: EV_RCEPSAU48X
    ODX version: 008014
    Long coding: 100000010001
    Trouble codes:
    46 Comfort System
    Serial number: 0168011766
    Long coding: 011A0EA000B900A18330033680000000
    Subsystems:
    System description: DWA-Sensor
    Software number: 8P7951177
    Software version: 0050
    System description: LIN BACKUP HO
    Software number: 1K0951605C
    Software version: 1501
    Trouble codes:
    static
    Priority: 6
    Driving cycle: 120
    Mileage: 79749 km
    static
    Priority: 6
    Driving cycle: 120
    Mileage: 79749 km
    47 Sound System
    System description: DSP Prem
    Software number: 8F1035223A
    Software version: 0030
    Hardware number: 8F1035223A
    Serial number: 94834002480600
    Trouble codes:
    00871 - Right front bass speaker Open circuit
    Intermittent
    Priority: 5
    Driving cycle: 120
    00875 - Right front treble speaker Open circuit
    Intermittent
    Priority: 5
    Driving cycle: 160
    52 Passenger Door
    System description: TSG BF
    Software number: 8T0959792G
    Software version: 0302
    Hardware number: 8T0959792G
    Long coding: 011C52325E09330C03
    Trouble codes:
    static
    Priority: 6
    Driving cycle: 120
    Mileage: 79749 km
    Date: 2022-11-28 18:27:49
    static
    Priority: 6
    Driving cycle: 120
    Mileage: 79749 km
    53 Parking Brake
    System description: EPB-4
    Software number: 8K0907801J
    Software version: 0001
    Hardware number: 8K0907801J
    Hardware version: H01
    Serial number: 10000000032695
    ODX name: EV_ParkiBrake
    ODX version: 001022
    Trouble codes:
    static
    Date: 2022-11-28 18:27:51
    Mileage: 79749 km
    Priority: 6
    Voltage terminal 30: 13.5 V
    Internal Fault ID: 208
    Network management state: normal
    Function light in parking brake button: On
    Red operating lamp: On
    Red warning lamp: Off
    Green operating lamp: Off
    Yellow warning lamp: Off
    Terminal 15 status: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    ACC requested apply: not active
    Auto Adjust: not active
    General Inspection Function: not active
    Internal Parking Brake state: static
    Status of parking brake button: not operated
    Status ParkingBrake left: Set
    Status ParkingBrake right: Set
    56 Radio
    System description: Radio U Basic
    Software number: 4G1035053E
    Software version: 0093
    Hardware number: 4G1035053
    Serial number: 227DV0C7560226
    Long coding: 040003010000000101
    Trouble codes:
    5F Multimedia
    System description: H-BN-RW
    Software number: 8R2035754C
    Software version: 0524
    Hardware number: 8R2035754C
    Hardware version: H44
    Serial number: 210CE0C7500017
    Long coding: 140A01030206A1ED45808B4E00000403FC0000020000000000
    Subsystems:
    System description: ROW 2012
    Software number: 8R0060884AJ
    Software version: 0403
    System description: DU7 High
    Software number: 8R0919604
    Software version: 0104
    Serial number: A130D70CS139409
    System description: E0380 Bedient
    Software number: 8T0919611C
    Software version: 0020
    Hardware version: H02
    Serial number: 00000001122009
    System description: CD-Database
    Software number: 8R0060961C
    Software version: 3638
    Trouble codes:
    Intermittent
    Priority: 5
    Driving cycle: 160
    Mileage: 79748 km
    Date: 2022-11-29 14:46:33
    02169 - Right front microphone Open circuit
    static
    Priority: 5
    Driving cycle: 120
    Mileage: 79749 km
    Date: 2022-11-28 18:27:58
    62 Rear Left Door
    System description: TSG HL
    Software number: 8T0959795F
    Hardware number: 8T0959795F
    Hardware version: H08
    Long coding: 010C12304009370C03
    Trouble codes:
    A9 Structure Borne Sound
    System description: SAS-GEN 2
    Software number: 8K0907159
    Software version: 0005
    Hardware number: 4H0907159A
    Serial number: 120313201099
    ODX name: EV_SoundActuaGen2AU64X
    ODX version: 002005
    Trouble codes:
    Dec 06 2022
    Anyone!
    Dec 04 2022
    Netherlands
    The faultcodes say
    -No signal to driver sides door control module
    -Right front bass speaker Open circuit intermittent
    That bottom one is the speaker you replaced right?
    I really dont like OBD fault codes, they are often wrong and when one thing fails it brings a lot of random codes that arent really broken with it...
    I'd try backtracing your steps.
    It worked, you changed something, it doesnt work now.
    Did you make any changes to the wiring? If yes> what did you change, got pictures?
    If you didn't, did you just unplug the old speaker and plug the new one in? If yes> try reconnecting old speaker and see if it still works (after resetting obd faults)
    Maybe faulty speaker?
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    Unplug the speaker, see if you get your door control module back. Also, did you do this work with the battery connected or did you power everything down first? If you did the former, you may have fried your door control module.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Dec 06 2022
    Quote Originally Posted by Spreuktegel View Post
    The faultcodes say
    Thanks for the reply, I agree with OBD11 irrelevant fault codes, I did replace the bottom speaker with a new and it worked well the scan I provided is when i took off the speaker. I also reinstalled the old speaker and clear the codes but 5 faulty codes comes back which are static including No signal to driver sides door control module. No changes made to the wiring, it was straight forward to unplug the door and connect back as is.
    Dec 06 2022
    Quote Originally Posted by JRYtheS4 View Post
    Thanks for the reply I did unplug the new speaker and plugged back the old one with no success, I also purchased exactly the same second hand door control unit and had the same results. No I did not disconnect the battery when I replaced the speaker or when took the door trim off, is there anyway to test the door control unit? cheers
    Dec 04 2022
    Netherlands
    The story is a bit vague, if you really want us to help you should describe accurately the current state, exactly what steps you took etc.
    But just a wild internet guess is that you fried it by not disconnecting the battery
    Dec 06 2022
    Please read the thread from the beginning I can not be more explanatory, why would you think the speaker can cause malfunction?
    Dec 04 2022
    Netherlands
    I did read it from the beginning. Since you aren't a qualified technician (or else you wouldn't post here but figure it out yourself, nor would you forget to disconnect the battery when working on electrics) there could be a step in your process where you screwed up. That's what im trying to help you with.
    Like the other guy said, probably not disconnecting the battery lead to frying the door control module.
    But because you can not be more explanatory i'll change my advice: Take it to a shop and pay them for a diagnose.
    Good luck!
    Sep 08 2020
    I'm just spitballing here since I can't be there to diagnose firsthand: based on the codes I would guess 1 of 4 things: broken wire(s) leading to the door control module, a bad door control module, or a speaker that is causing a short, or you've damaged some other unrelated module by connecting/disconnecting things while powered.
    Just as an example, I had a friend at work trying to fix his lock cylinder on his Tiguan. He ended up frying his power steering rack module and his steering lock module because he was plugging/unplugging all the connections under his wheel a bunch of times with the battery connected. These modules really don't like it when you do that. They don't seem to be built to handle that kind of abuse. I was able to repair his steering wheel module with him but the rack had to be totally replaced.
    Dec 06 2022
    Thanks for the reply, let's assume that the door control unit has been fried, but it has been replaced with another one with no success while was battery disconnected, initially the door internal plug was disconnected while the ignition was off. Furthermore, the left hand door works as normal and the car has no problem starting, gear lever can be released manually and car moves, fuel door can be locked unlocked so is the boot, all the other functionality in working order such as lights, blinkers, air conditioning, MMI etc. Also, please correct me if I am wrong but the door module does not power central locking or the speakers. Therefore old and new speaker works fine but strangely the central locking does not work on driver door. It makes me wonder if the Window motor module has an issue and it completes the circuit for door control module.
    Please see the log below prior to replacing the speaker, since then the car has not been driven and everything seems to be fine.
    OBDeleven data log
    Date: 2022-11-26 16:36
    Car: Audi S5 Cabrio
    Year: 2012
    Mileage: 79740 KM
    01 Engine
    ODX version: 002005
    Trouble codes:
    02 Transmission
    ODX version: A02196
    Long coding: 000001
    Trouble codes:
    03 Brakes
    Long coding: 295D0C
    Trouble codes:
    Trouble codes:
    05 Keyless System
    Subsystems:
    System description: FBSAUDIB8 IDG
    Software number: 8T0959754R
    Software version: 0072
    Hardware version: H61
    Serial number: 0512000021956002
    Trouble codes:
    06 Passenger Seat
    Trouble codes:
    08 Air Conditioning
    Trouble codes:
    Subsystems:
    Long coding: 00FD11
    Long coding: 02005D
    Trouble codes:
    0E Media Player
    Trouble codes:
    15 Airbag
    ODX version: 001004
    Trouble codes:
    16 Steering Column
    Long coding: 000036
    Subsystems:
    Trouble codes:
    17 Dashboard
    Trouble codes:
    19 Gateway
    Subsystems:
    Trouble codes:
    03041 - Energy management active
    static
    26 Roof Control
    ODX version: 001008
    Long coding: 010000
    Trouble codes:
    36 Driver Seat
    Trouble codes:
    42 Driver Door
    System description: TSG FA
    Software number: 8T0959793G
    Hardware number: 8T0959793G
    Long coding: 011C52725E09330C03
    Trouble codes:
    ODX version: 008014
    Trouble codes:
    46 Comfort System
    Subsystems:
    Trouble codes:
    47 Sound System
    Trouble codes:
    52 Passenger Door
    Trouble codes:
    53 Parking Brake
    ODX version: 001022
    Trouble codes:
    56 Radio
    Trouble codes:
    5F Multimedia
    Subsystems:
    Trouble codes:
    62 Rear Left Door
    Trouble codes:
    72 Rear Right Door
    System description: TSG HR
    Trouble codes:
    ODX version: 002005
    Trouble codes:
    Dec 06 2022
    Good luck!
    Thanks but no thanks, and please take your attitude elsewhere, this is a public forum and it is developed for the people like me for DIY diagnostics and fixes. My advice is to stay away from the forums because it is obvious that you don't know what are you talking about so please stay away.
    For anyone else reading this post, J386 door control module is not an egg that you can fry it by disconnecting a 30 pin cable or else it would have shown in scan log as faulty, and the door speaker has nothing to do with the door control unit, the J386 and J389 module which are related to in the diagram. Upon individual circuit testing there is no electricity flow in pin 19 and there is no break in pin 19 and 20 from door harness. Fuse 9 in column C of in the right rear which supply the 12v to J386 is intact. I will post the further testing anyone who has the similar issue.
    Dec 04 2022
    Netherlands
    Quote Originally Posted by sydbloke View Post
    - I had a whole text here prepared which you certainly wouldn't appreciate. but lets be nice since its the holiday season, and i have nothing better to do-
    The electrical drawings i use kind of confused me at first, but i think i might have something, after 2009 they might have changed the fuse locations.
    Fuse 9 in the right of the luggage compartiment was "Passenger door ctrl module" Before 2009, but after 2009 its "AWD ctrl module 35a" (on my drawings for 2012 A5's)
    On my drawings the fuse(s) for J386 (after 2009) "Door ctrl module" are 2 separate fuses on the right of the steering column, a panel on the right side of the dashboard (right hand drive i assume)
    When you open that panel theres 3 vertical rows. The following are for the center row:
    8 - Fuse 8 on fuse holder C -SC8- 30 A - Driver door control unit -J386
    11 - Fuse 11 on fuse holder C -SC11- 15 A - Driver door control unit -J386-
    Edit: The drawings for the door ctrl module actually confirm this, the 12v on pin 19 comes from "ST2 SC8" Which is referring to the fuse 8 mentioned above on the right of dashboard
    If that doesnt work:
    When you say "there is no electricity flow in pin 19 (flow is Amperes)", do you mean there is no 12V on it?
    Did you use a ground on the chassis, or did you use the brown cable as a ground?
    Sep 08 2020
    You definitely sound like you're making good diagnostic steps, but I have to just say that disconnecting your battery before dicking around is the right decision. So no, for anyone reading this, you can very easily fry modules. It probably didn't happen to you, but it can happen, and best practice should be to do any wiring unpowered. Obviously during diagnostics that isn't possible, so it should be done with great care. All you have to do is short one of those 12V lines to ground and you'll be buying a new module. Which is a shame because all that probably failed is a single $0.10 diode.
    The current state of events is basically post #11 right? I had a little trouble understanding your post after that.
    Dec 04 2022
    Netherlands
    Basically the fuses he checked were incorrect according to the schematics i have, the fuses for door control are in the dashboard side panel, not in the rear.
    Wonder if he fixed it, since he didnt respond here or the other forum he posted the question.
    Jul 16 2018
    Atlanta
    OP is a RHD vehicle. So driver door is right side. Right side door control module fuses are in the right rear. Left side door control module fuses are in the left dash.
    Dec 04 2022
    Netherlands
    Quote Originally Posted by Smac770 View Post
    I re-checked, but it really still says its in the dashboard side fuse holder… even on RHD models, (even shows a picture of RHD model location).
    The drawing of the door control module itself also indicates that the power is coming from this dashboard fuse box..
    I’m assuming the 2012 cabrio model has the same schematics as the 2012 coupe except for the detachable roof?
    Jul 16 2018
    Atlanta
    From the A5 wiring diagrams:
    J386 T20f/19 (driver's, so front right in this case, door) is connected to T27a/19 (the front door to body junction, driver side).
    For "*3 Only left-hand drive models", T27a/19 is then connected to panel C column 2 fuse 8.
    For "*4 Only right-hand drive models", T27a/19 is then connected to panel F column 3 ("C") fuse 9.
    J387 T20g/19 (passenger's, so front left in this case, door) is connected to T27c/19 (the front door to body junction, passenger side).
    For "*3 Only left-hand drive models", T27c/19 is then connected to panel F column 3 ("C") fuse 9.
    For "*4 Only right-hand drive models", T27c/19 is then connected to panel C column 2 fuse 8.
    But that's for B8.0. The OP, though a 2012, is a B8.5, as it has a J500.
    Panel C is on the driver's end of the dash. It seems odd to run the left side door power across the dash to the right end, but that's how it plays out. The left side doors run off panel C on the driver's end of the dash. And the right side doors run off panel F in the right rear.
    Not sure what materials you are referencing.
    Dec 04 2022
    Netherlands
    Interesting, im not sure i follow you, but seems like we have different schematics for the same car, or we are reading them wrong.
    There is indeed a change in B8 to B8.5, in B8 its in the rear on my drawings, B8.5 front side panel.
    However, the best way to find out which schematics are right, would be to have OP check it out.
    Seems like he fixed it somehow since he isnt responding anymore. Or maybe he scrapped the car
    Jul 16 2018
    Atlanta
    So for the B8 sedan, wagon, coupe, and sportback, I can confirm the wiring as I have the wiring diagrams as Audi put out on erwin. I do not have any cabriolet documents, no one has posted any that I've found, and I'm not paying to go back into erwin for docs for a car I don't own. Obviously, the coupe does not have the rear control modules. The cabriolet does, as it has rear windows that have to go up/down; that's the only reason they are there in a cabriolet.
    As the B8.0 wiring is different, and convoluted with the running change, and the OP is B8.5, let's just draw that out for our purpose.
    B8.5 wiring document raw info:
    B8.5 wiring diagrams, simplified to separate LHD and RHD layouts:
    Jun 25 2019
    Ottawa/Ontario/Canada
    The main wiring harness for the inner door panel can be be locked by the blue lever and not be all the way in. Happened to me twice. Remove and reinstall connector and test while panel is off door.
