Originally Posted by
workerONE
Here's a photo:
Lane assist is working but I don't have an option to set Steering correction to Early
When I switch lane assist on going over a certain speed I see the icon with yellow lines, and if the car drifts to the edge of the lane the steering wheel vibrates and there's a steering correction (and on the MMI icon the lane changes color). But the system only corrects once the car hits the line. According to the manual (and it seems like other forum members) there's supposed to be an option to set "Steering Correction" to "Early" so that the system keeps the vehicle in the center of the lane.
Thanks for the pic and confirmation you're seeing the icon with the yellow lines and that if the car drifts to the edge of the lane, that Lane Assist will warn you with corrective steering before "exiting the lane". Per the manual, "if the system must intervene for a long period of time, a message will request the driver to drive in the center of the lane, and the steering wheel will also vibrate lightly when exiting the lane." The manual goes on to state "That if Audi active lane assist intervenes multiple times when no steering activity is detected, the steering intervention request will provide a warning using audio and visual signals. Take over the steering and keep your hands on the steering wheel so that you will be ready to steer at any time. The system may no longer be ready to provide warnings after a short time, and it will only become active again later. I
f the driver does not take over steering, Audi active lane assist will be switched off."
So apparently if there is no or limited participation in correcting the steering from the driver, the system turns off. I concur that the manual does provide instructions for adjusting the Audi active lane assist individually. As noted, the settings apply to the MMI, where in the home screen you select VEHICLE > Driver Assistance > Audi active lane assist/Land departure warning. The possible settings are as follows:
Steering correction - In the
Late setting, the steering correction will only occur shortly before a wheel crosses a detected lane marker line. In the
Early setting, steering correction occurs continuously in order to help the driver keep the vehicle in the center of the lane. If the steering correction cannot be set, the steering correction will function in the
Late setting.
Vibration warning - You can select if you would also like to be warned using a vibration in the steering wheel.
Tips - Certain settings are automatically stored and assigned to the remote control key being used.
It would seem like the Early setting would be capable of making the continuous corrections needed to autonomously keep the vehicle steering into the center of the lane. But I suspect it still requires sensing the driver's hands on the wheel and at least some degree of human participation in the steering of the car. As a purely
assistive feature, I can't envision the feature taking full responsibility for steering the vehicle to your destination, like a Tesla might be capable of doing. Maybe that'll be a B10 feature!
