Results 1 to 8 of 8
    Oct 10 2016
    Colorado
    Door window glass replacement
    So strange situation here but all four door glasses have been broken!
    Can anyone please point me to any DIY guides that can help me with an easier installation process for these window glasses? I picked up the glasses from a local salvage yard. they weren't nice taking off the glasses, broke parts, ripped the rubber liners, etc. I'd appreciate if someone can point me to a factory manual or video for an easier installation.
    Thanks and much appreciated.
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    YouTube has a bunch of videos. Not that difficult to find...
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Oct 10 2016
    Colorado
    I found some but not specific to what I'm looking for. I know how to remove the door panel and other things, it's inserting the glass that I need instructions on. I don't want to tear up the rubber weather strip. Wondering what's the right method to do it.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    The process is similar front and back but the back is far more involved than the front.
    The front process is pretty basic:
    - Remove the trim piece on the door
    - Remove the door handle trim
    - Remove the 5 torx screws holding the panel on T30 or 25 IIRC
    - Use a pry tool or panel release pliers to undo the 9 pressure clips
    - From the bottom pull the door panel forward and then slide it up and out of the window channel
    - Remove the wiring harness clip and the door handle pull
    - Remove the plastic hole/moisture cover
    - Remove the speaker 8MM bolts and disconnect the wiring harness
    - Roll the window regulator down until you can see the two plastic clips holding the window to the regulator (helps to have convenience key)
    - Use a screwdriver and push the white plastic clips back holding the window to the regulator - back clip first
    - Angle the front of the window down and slide the back of the window up and out on the outside of the car
    - Reverse ensuring the front of the window is in the channel by looking through the speaker opening (convenience key helps here to ensure all is working before putting it back together again.
    Back:
    Basically the same process to remove the trim, door panel, speakers, moisture cover, but where it changes is that you need to remove the window seal/channel in the back and the clips that hold the window to the regulator are a push pin type that are very difficult to remove.
    - Follow process above for front windows until you roll the regulator down.
    - Remove the interior window frame trim that covers the exterior painted colored parts of the door
    - From the inside remove the covers for the back piano black trim piece outside the car near the c-pillar and remove the 2 1 Torx screws
    - From the outside of the car and with the window in, gently pull the whole window seal/channel up and out
    - Use a long screw to insert it into the push pin clip that holds the window to the regulator and firmly pull out to remove it with pliers
    - Slide the window up and out like the front with the back of the window coming out first
    - Reverse but put the window in first and then the seal - this will take some time and finesse to not rip the $400 seal for the window and get everything set correctly.
    I have the manual process on my phone somewhere and will post images when I get a chance. This is all from memory so I may have missed a step or two. Buy your replacement windows from eBay…that’s where I grabbed mine for this process to not lose my tint.
    EDIT: updated with images but I had to find them again and only have my phone on vacation, so the screenshots aren’t standard sizes.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Oct 10 2016
    Colorado
    Thank you so much for these pictures. I watched them remove the glasses from the door and they brutally ripped the rubber trim pieces. The top of it seemed glued because they were in there pretty good.
    I'll attempt it today.
    Oct 10 2016
    Colorado
    The back door looks pretty intimidating. Don't know if I can do it without damaging the trim or panels!
    Oct 10 2016
    Colorado
    Got it done. Wasn't as bad as I thought. I broke a few tabs on each door panel when I was prying them out.
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Quote Originally Posted by eclipse1 View Post
    Yup happened to me too when I was attempting to fix a rattle when the door closed with window down. Door card flexes slightly when pulled but you have to look for it specifically. I wouldn't worry about those tabs.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
