Results 1 to 16 of 16
    Established Member Two Rings 714RS3's Avatar
    Nov 13 2022
    Lake Forest, CA
    Launch Control Won’t Engage
    Hello everyone,
    I am having an issue engaging launch control on my 2017 RS3. I’ve tried all the different combinations. Dynamic, press ESC once and/or ESC completely off, steering wheel completely straight, engine and transmission warm, manual and automatic sport, left foot hard on brake all the way to the floor and floor throttle. Even trying all the different combinations it just brings revs up to maybe 1k RPM’s and spins the wheels a bit or bogs instead of engaging launch.
    The interesting part about this, is that when I first got the car and was showing some friends I was able to launch it 3 times easily using the standard procedure. After those 3 times I haven’t been able to get it to work. I know the previous owner of the car and he said he only launched it maybe 15 times so I highly doubt the 200 limit was reached.
    The only thing I could think of is that it won’t engage due to my brake pad wear limit being reached up front. Not sure if there’s any correlation but I just wanted to see. Very strange I can’t get this working when It was so simple the first few times.
    Any help would be greatly appreciated.
    Junior Member Two Rings
    Aug 30 2020
    You probably have but just make sure that the car is also in S mode. I had issues trying to launch my car when I first got it, found out I was still in D mode.
    Nov 13 2022
    Lake Forest, CA
    Quote Originally Posted by Rs31000 View Post
    Yeah I’ve made sure it’s in S mode as well. I just hit the little down arrow under D to throw it in S. Still no luck :/ very puzzling
    Junior Member Two Rings srtviperjr's Avatar
    Oct 17 2017
    Ontario Canada
    2017 I bet they hit the 200 mark for launches. Wonder where you can see that?
    2023 Vegas Yellow RS5 Sportback - Competition
    2019 F-Type R Convertable - Sunny day toy
    2018 Panther Black RS3 - Winter car
    2014 Gunmetal Grey GT-R - Summer toy
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    I'd start by using vcds and ensuring the launch count is actually under 200
    Mar 09 2018
    2018 RS3
    all stock?
    probably the launch count exceeded...
    Florett RS3+DS1+034TCU
    Nov 13 2022
    Lake Forest, CA
    Quote Originally Posted by tegxsi View Post
    all stock?
    Yup all stock. I guess I’ll have to get one of those OBD ports and see what the count is at. Weird that it must’ve been at like 197 when I got it cuz I was able to do 3 before it stopped letting me.
    Nov 13 2022
    Lake Forest, CA
    Hey guys, quick update.
    I just got the 034 Motorsports Stage 1 E85 tuned flashed with the TCU tune. Shifts are improved, nice parking lot free revs, and the speed is insane.
    However, even with the ECU/TCU tune and the new brakes I still cannot manage to get launch control engaged. Tried every combination out there to try to engage it with warmed up oil and trans temps, traction settings, straight steering wheel, etc.
    Anyone have a clue as to what else it might be? My launch counter should be gone with the tune.
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    I would check the lunch counter, prior to investigate other possible reasons
    2020 TT- RS
    ex 2018 TTS
    Nov 13 2022
    Lake Forest, CA
    Quote Originally Posted by kevin#34 View Post
    I had a shop check it via VCDS. They said it was at 200 which was the max, but the TCU software I recently installed raised that amount to allow for more launches.
    Senior Member Three Rings NapalmEnema's Avatar
    Jul 02 2022
    2022 Kyalami Green RS3
    Houston
    Quote Originally Posted by 714RS3 View Post
    I don't see how it would reset that, and if it is purported to do so you should follow up with the TCU software vendor to see why it will not engage. That being said, your car has been launched 200 times, maybe just enjoy it without beating on it more? Feels like they put in a max 200 launch number for a reason...
    2022 RS3 Kyalami Green
    2017 M2 Performance Edition - Arctic White
    2021 Type R - Shadow Grey Pearl
    Dec 03 2020
    GT
    You have to press hard the brake padal
    Feb 17 2018
    California
    If you're at 200 launches and the previous seller told you "15"... you might have way more going on with your car mechanically than you realize. I would have your shop or dealer do a full diagnostic on your car to make sure. You're already at 2 months from your original post trying to figure this out.... There are plenty of reputable Audi / VW shops in OC that can help you. You should also check with APR and see if your car ever had a tune assigned to the VIN. I don't know if Unitronic can do the same but checking this will help you further verify how "stock" your car was from the previous owner.
    Jul 13 2018
    Winnipeg, MB, Canada
    Quote Originally Posted by Conflicker54 View Post
    Yes, anytime I have a problem with engagement, its because I'm not pressing hard enough. You really have to muscle it.
    Nov 13 2022
    Lake Forest, CA
    Yeah guess I wasn’t pressing the brake pedal hard enough. All good now, I appreciate it
    Junior Member One Ring RHGregory3's Avatar
    Aug 21 2022
    20' RS3 Nardo Edition / 23' 2.0T VW Tiguan / 16' Kia Sportage (Commuter)
    Bucks County, PA
    I believe there are some tunes that will remove the limiter, Unitronic advertises this. I would have to agree with the above posters though, def get that thing gone over - the gearbox has to be hurting unless it was replaced already, and even then - I'd rather know now.
