I had a chance to do couple of more track days. You’re right, seems like 38 or 39 psi is a good spot. I also noticed that starting out 33 psi cold front and rear, combined with taking it easy the first warm up lap, gets the tires in good range.
However, these trofeo r tires most definitely need more negative camber. Looks like -3 at the minimum or more. Mine look like only one half of the tire is being used. Getting pretty chewed up, where the other half looks good.
In regards to those brake pads, so far a pretty good experience. They’re stopping well, however 3500 might be a better option for very fast and aggressive because of higher temp rating. I noticed they are wearing out quick under heat.
Also seems, most of the noise does come from combination of dust deposit and pad transfer on the rotor itself.
I think RT660 is a good tire for a lighter car. Not so much for RS3. Wish Hankook made their RS4 tire in 19in sizes that fit our cars. Those tires wear like a tank and don’t require extreme camber. They’re a bit slower, but who cares.
Originally Posted by
S3DUDE
I normally arrive at the local track with warm tires , typically in the high 40's (49PSI or so). The track is like 35 minutes away from my house. Before we are racing on our first session we drop the tire pressure down to 40 or so. After the first session it goes up again so our sweet spot is around 38PSi. In summary, we see an increase of PSI going up like 14-15 psi total combined after driving on the street plus driving it for a coupe of sessions at the track.
The Trofeos (your trofeos) at 30-31 PSI on cold seems like very low to me. How many miles do you have on your rotors? are your rotors OEM? My rotors had a small vibration after the second session but it went away after driving 70 miles doing errands. It was just brake pad residual smeared. I did cleaned the rotors and calipers well, I gave it a good wash, cleaned the calipers with a brush and blasted the rotors crossdrilled holes with compressed air and sprayed brake cleaner. I think that you would agree with me that the IS3000/IS2000 is one heck of a Hybrid combo brake alternative(track/street). Just curious but do you torque your wheels? I do. it can make a big difference. I am going to be doing a Time Attack at the Musselman Honda Circuit this Saturday. I haven't even touched my camber yet, in fact I don't have an alignment since putting the KW V3 5-6 months ago.. A buddy of mine has a shop that specialized on track custom alignments but I don't want anything aggressive. I am very happy with my KW V3 combo and Neuspeed sway bar but I am looking to get the 275/30/19 Falcon Azenis RT660 and 245/35/19 to put the cherry on the cake.
