Results 1 to 13 of 13
    Established Member Two Rings CDN BCN's Avatar
    Jan 07 2014
    2015 GMC Terrain
    long island new york
    what now... cost to repair is more than the car is worth
    hey everyone,
    My poor B8 is near it's end... the cat's are blown, before the Cats i was blowing dark smoke out the exhaust (yes i had the PCV valve etc replaced only 2 years ago) and now i get a transmission warning from time to time (might have something to do with the cats though)
    there is a CEL, i believe it's for the oxygen sensor downstream in the exhaust.
    my question to the group... what have others done with their cars when the repairs get to be too costly?
    i'm pretty sure i could part it and make a couple bucks that way. but it would be minimal at best.
    i feel a dealership will basically laugh in my face if i tried to trade it in...
    i've thought about donating it... but haven't look to much into it.
    thank you in advance.
    Steven
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    I mean, you can get the Magnaflow Cats for like $1K each. Better than OEM that's required for CA that's 3K each.
    Your dark smoke is likely your valve stem seals needing replace, assuming the smoke goes away after warm up. Else you're running rich.
    The transmission, idk.
    The O2 sensor shouldn't be too bad.
    So maybe 6K in repairs.
    If the repairs cost more than the car, and you're not attached to it. Time to list it and sell it. I mean, you might be able to get at least the cost of the repairs for the car, maybe a bit more.
    2013 S4 6MT mods:
    APR intake backpipe w/ modded stock airbox, AFE Air Filter, CTS 187mm crank, APR 57mm charger, APR HX, Stasis Catback, CR-15, 034 Stage 2+/034 Stage 1 CARB
    Junior Member Two Rings axisB8A4's Avatar
    Apr 19 2015
    B8 A4 MT, B8.5 S4 MT
    New Hampshire
    Sorry to hear that your B8 is near the end. I have been in a similar situation for the last year with my '09 A4.
    Last winter I wound up picking up a '13 S4 and have relegated the A4 to driving around in the snow and hauling gear and dirty stuff around.
    Something is really wrong with my rear driver side suspension that it makes a clunking noise but I haven't had the time to really look at it. It burns a quart of oil about every 600 miles. CEL is on and it has a bunch of codes related to the O2 sensors and misfires. I need to replace suspension bushings and ball joints probably (boots around the front look okay though). Basically a bunch of stuff but I can still drive it around town as a beater almost, although it pains me to call it that.
    The way your car is now, can you still get it inspected and drive it as a second car? Could you use a second car?
    It really depends on your situation but I would say for me that the car is worth keeping around as it's paid off and not much to insure. If you don't need a second car or can't keep one then unfortunately your best bet might be to sell it privately or part it out like you said.
    Sent using Audizine Forum mobile app
    '09 Brilliant Red A4 MT, APR Stage 2
    '13 Misano Red S4 MT, 034 Stage 2
    Apr 19 2015
    New Hampshire
    Something that I neglected to ask, but do you want to replace the cats and O2 sensor(s) yourself?
    I only keep my busted A4 around because I can work on it myself to get it to pass inspection. If you don't want to do that then definitely time to sell.
    Senior Member Four Rings
    Jun 08 2021
    PA
    This is why maintaining issues is important. once you let multiple issues build up its big money. I always preach that maintaining these cars is essential so you don’t end up with a huge mess of issues that have to he repaired at once. You say b8 so assuming it’s 12 or older id just trade it and be done. The dealer will just take it to auction if its nice still drives you should still get a few grand id think. No sense in donating a car like this. Its just too expensive to fix for whoever ends up with it.
    Sep 16 2020
    West Michigan
    Fix the car yourself, find a buddy to help, or find some local audi enthusiasts to see if someone can fix it for a fee.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Buy a (20y/o)Camry. You can't afford to fix an Audi...sorry...I tell this to a lot of clients....usually Benz owners though.
    "this car will bankrupt you...buy something else"
    With that being said, if you love the VAG and have a place to work on it yourself...that changes the game......
    B6 S4, B8 A4, 8P A3, and something, something.
    Aug 08 2010
    Alaska
    Unless you're foolishly bringing this to dealers for repairs, the TCO is going to be pretty reasonable for what you're getting in return.
    Even if you spent $10k in repairs to fix it up nice, what other vehicle could you get for $10k instead?
    That would be how I would approach the decision. Unless you're just mentally done with the car, then I guess time to move on...
    If you keep it, the "secret" is to learn more about the car and what is involved with various economical repairs, take a little time to locate used parts, find a mechanic that does side work, etc.
    Moreover, f you got a diagnosis from a shop that likes everything perfect, then they are going to throw the kitchen sink at you for stuff they want to do to it. Why wouldn't they?? That is how they make money. Your job is to push back, ask questions, research, etc. If I had a nickel for every time I was told I needed new shocks, brakes, bushings, new seals, etc., I'd be a millionaire....
    Feb 07 2018
    PDX ish
    just did a bunch of work. Got quoted 5k to do half of it. Just gotta decide if its worth owning and if it is learn how to do it yourself. Nice group of enthusiasts so while you might not have the experience, there is almost certainly a diy to go along with the service manual.
    And I redid my pcv 2 years ago, had black smoke, redid it along with a lot of other work but pcv looked fine. Also did the pcv breather hose that connects to your intake and now im smoke free. Thought mine was valve seals as mentioned above but my issues were definitly resolved.
    Good luck.
    Sent from my SM-G973U1 using Audizine Forum mobile app
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
    Sep 16 2020
    West Michigan
    Quote Originally Posted by hardfive View Post
    Good luck.
    I was planning on doing a somewhat major service to mine and definitely was not looking forward to it, then the cat broke at the flange and forced my hand.
    I have never done so much work on an Audi before. I have done plenty of wrenching on much more simple cars.
    Services performed:
    PCV, PCV hoses, water pump, thermostat, vacuum pump, carbon clean, removed and gutted cats, rewelded cat flanges, fluidampr w 189 ring, serpentine belt, supercharger belt, JHM hx, 034 engine mounts, oil cooler gasket, GCA honeycomb grille.
    It was a lot of work and pretty overwhelming at first, but now I am familiar with the car and how everything works and wouldn't hesitate to tackle it again. It actually wasn't as terrible as I was initially thinking.
    OP, you can do it!!! Just take your time and research what you need ahead of time so you are not waiting for parts/tools like I did!
    Feb 07 2018
    PDX ish
    Quote Originally Posted by sepheroth86 View Post
    Services performed:
    Yeah. My list was pretty similar. Put test pipes on a few years ago, so nothing there but did valve cover gaskets and total rebuild of sc. Basically everything on the way to a carbon clean was cleaned, rebuilt, or replaced.
    Actually considering a q7 to replace our mdx as the 2017 still uses the 3.0 and I basically touched every part between my swap and major maintenance. Im too cheap to pay someone to service a euro it seems so getting one with the 3.0 semms like the right ticket.
    And for as much greif as people give Audi, I actually find most of there bolts/fastners are easy to access if you know where they are. Hard to find sometimes, but not awful to work on once you know, if that makes sense.
    Definitely doable op. But yes on parts research. I spent a few weeks as I'd be missing some small gasket and have to wait a week for FCP to get it to me.
    Mar 14 2021
    Australia
    I had strange 02 sensor issues. A full ECU reset resolved the issues for me. However mine is the 3.0tfsi.
    Jan 07 2014
    2015 GMC Terrain
    thank you everyone for your responses!
    believe me, if i felt it was worth putting the money into it i would! This has been the most fun car i've had.
    the cost to repair wouldn't be so bad if the labour rate wasn't a factor. i love to work on cars but these repairs are more than i personally would take on.
    I tried the O2 sensor with no luck. the black smoke is a regular thing, not just when the engine is cold.
    the PCV, hoses etc were replaced 2 years ago. it helped with the black smoke and slowed down the amount of oil i was burning, but now i'm back to a quart every 500-750 miles.
    one option would to be to keep it as a project car...
    thank you again everyone!
