Results 1 to 13 of 13
    Senior Member Two Rings Vrsc's Avatar
    Aug 24 2016
    Celebration, Florida
    Need ET for These SQ5 black optic wheels
    Purchasing 2019 SQ5 prestige with black optics package in need of the ET
    Specs for wheels
    audi 20" 5-arm-rotor design wheels, anthracite finish
    I believe they are 20x8 but new the ET can start looking for wheel replacement for a flush figment!
    2016 S5 Sepang Blue,
    Full Nappa Black Leather, Slammed on KW Height Adjustable Spring (HAS), Color Matched Sepang Painted Calipers, Chipwerke Pro
    HRE P101SC 20x9.5 ET 19 (all 4 corners), Continental Extreme Contact Sport
    275/30/20, Xpel Ultimate Film seamless Custom fit on about 1/2 the car, 30% Ceramic Tint including full windshield
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Quote Originally Posted by Vrsc View Post
    start looking for wheel replacement for a flush fitment!
    21x10, or 10.5 if you want a tiny bit of stretch and your rims to be extremely flush bordering on poke. ET30 or 32, go with 295/35. You're welcome.
    If you really need to know, the stock ones are ET39. But I gave you the best flush fitment numbers, so you don't have to do any guess work. Pretty much everyone on here runs those specs, I'm sure someone can post a pic.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Aug 24 2016
    Thanks. If I wanted to to get through the winter as my with these as my winter wheels, what size spacers front and rear is recommend for a nice flush figment
    Mar 25 2015
    Placer County
    depends if you remove the plastic rock chip guards or not. If you don't, then not much. at et39, on 255's, add 5mm to my specs since I'm ET34 on 255's.
    I can get away with 15mm rear, 20 when I'm not too low. 12 up front, or 15 not that low. Before I got rid of the plastic guards I got away with 12 out back and 10 up front, pretty slammed.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jul 16 2018
    Atlanta
    Type FY (B9 Q5) 20" factory is 255/45r20 101W XL on 20x8.0 et39.
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Specs for wheels
    The original rim models for Q5/SQ5 18", 19", 20" have ET39
    Only 21" has ET34
    Aug 24 2016
    Thanks.. for 15mm spacers for front and 20mm spaces for the rear. After the winter will be deciding on new wheels
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Specs for wheels
    Here -- https://www.original-felgen.com/80a601025aquj2k80.html
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Jun 24 2019
    US
    Quote Originally Posted by Gunnarrrrr View Post
    For spacers, would you recommend DRA style or stay away from them?
    Mar 25 2015
    Placer County
    Quote Originally Posted by scavokRS3 View Post
    I wouldn't, there's no reason to not just run normal spacers with longer bolts. Those DRA spacers always looked a little sketchy to me. You can get away with 10mm spacers on the stock bolts. If you go any bigger than 10 you'll want to pick up some longer ball-seat bolts. just take a measurement of your stock bolts and add the thickness of your spacer so you're not reducing your thread insertion by more than 10mm. If you do 20mm spacers for example, try to get some bolts that are about 15mm longer, in case you end up dropping to thinner spacers and you have some mm's to work with.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jun 24 2019
    US
    Thanks for confirming. I'm deciding on 12mm front, 15mm rear, or 15 and 20.
    Mar 25 2015
    Placer County
    most people on here run 15 and 20 with the stock 21’s. they’ll work fine if you aren’t on HAS springs slammed all the way down. if so you might find the occasional rub a little annoying. But it’s minor.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jun 24 2019
    US
    I have TSW Watkins ET32 for my winter setup. I don't recall what my stock 20's are. I only want to buy one set. Think I should still go with the 15 and 20 setup? I'm only going to be on lowering links.
