Here is one of my best laps, and after that, a couple incidents where I had to deal with some oversteer.
There are vids of two more session on my channel with a wider view and less smoothing. Still trying to figure out the best GoPro settings.
This is my 5th track weekend. All of the others were in a 2016 Focus RS, which was stock. This was my third time doing this track in this direction, and first time in the blue group. Definitely not a pro.
My first time at the track ever was this same track and direction. I ended the day with a 2:00 flat lap. Second time with the same config, I got a 1:58. This time in the RS3, I got several laps in the 1:54 and 1:55 range. So much faster and more consistent.
Overall, I loved the car. For how great it is as a daily, it's amazing that it performs this well on the track. It's only 50 more HP on paper, but it feels like much more than the RS. Part of that might be the DCT. I was hitting speeds 10+ MPH faster on the straights, without late braking.
I do think it was more playful than the Focus in terms of balance. It did oversteer some, but very minor. It was pretty balanced, but I feel I actually get more communication through the chassis. Part of that might be the much softer suspension. The Focus's soft setting is much more firm than the RS3's firmest. I also didn't mind the lighter steering.
That moment at 15:25 in the video was the first time I though "Shit, is this gonna be my first spin?". But it wasn't too hard to reel it back in.
I did not have any issues with the car. The tires did get a little slippery as they heated up, but the are the Potenza Sports, so no surprise there. The brakes required a little bit more pedal travel to stop on the second day, but they held up really well in terms of wear. I was also on stock fluid. Different story for the tires though. All of the outside edges of the tread lines started coming off on all four tires. I thought this may be a problem after seeing a Tire Reviews video on YouTube, where there was a similar issue.
In terms of what can be improved:
- Track brake pads would help for sure, but stock did hold up well.
- I'm not a fan of the drilled rotors. The holes filled up with pad material quickly, and there was some vibration under moderate braking after day one, but it went away. I actually had quite a bit of material in the holes before going to the track.
- Better tires. The Potenza Sports drive well, but they wear fast.
- MMI is annoying. I disabled pre sense each time, but you will still see it pop up a lot. I also had it freeze on my randomly. The wireless Android Auto is a little flakey as well. Overall, this has been my one real gripe with the car, but it is not major.
- I thought the car was really balanced in the performance mode. I don't think it needs a rear sway bar as is, but it might help. Maybe a rear bar with a square setup, so the tires can be rotated would be similar.
- The exhaust is too quiet. I wanted to use the paddles to shift, but it is hard to hear the exhaust with all the wind noise, and I didn't want to need to use my eyes for shifts. Oddly, the automatic mode in performance doesn't always hold revs high enough, and it may downshift when getting on the gas out of a corner.
- The seats aren't perfect for the track. They're fine if you can get the seatbelt to lock and stay locked, but mine would usually come lose halfway through a session. If they just had put the holes in for the shoulder straps for a Schroth Quikfit, they would be great. I would love a bucket that kept the power and memory functions, but I don't think that exists. I'll probably just try to find a way to keep the seatbelt locked.
- NapalmEnema made a post asking about a float feeling when going over elevations. The track does have a single small hill, called "The launch". If I went over this on full throttle, some of the wheels would actually lose traction and spin, then land and give a small "boost". It was fun, but probably not good for the car. I didn't have this issue in my other car, but it wasn't as fast and had much stiffer suspension. Maybe stiffer springs might help here? But I wouldn't want to lower my car more than a cm or so, and I really like the stock dampers.
Overall, it was great. It was exactly what I hoped it would be and a little more. For now, the plan is to just find good brake pads and a way to lock the seatbelt. I will probably also go to 18" wheels, and sooner than I thought due to tire wear. I might keep the 19s for a daily tire, and then track the 18s.
