    Junior Member Two Rings
    Nov 21 2018
    Kent
    P284F - Uncommanded Movement Intermittent
    So I was driving my car and I went to overtake a Lorry got gearbox malfunction etc
    pulled over restarted no problem. Got home fine no issues thought it was a one of
    since then i did a 100 mile round trip no issues with a mixture of driving, no problem
    the past week its happened multiple times randomly the car still feels fine tho drives fine shifts fine etc anyone had this issue before?
    error code is P284F - Uncommanded Movement Intermittent
    kind regards,
    Thomas
    Nov 27 2015
    UK, West Berks
    That's one of the rarer fault codes relating to the mechatronics which controls gear shifting. What is the car build year and how many miles has the car done? What is the service history for the gearbox (specifically the gearbox, not just general service)?
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Nov 21 2018
    Kent
    Audi A5 2013 3.0 TDI Quattro stronic.
    95k miles i owned it since 40k so most of that was me, I had the stronic serviced by 4 rings dartford who said there was no debree in it and oil looked good. I since serviced it myself in 2020 because of a transmission leak from the transmission cooler.
    I carried the work out myself with aid from my audi tech friend on the phone, videos images etc and managed to do it myself new strainer checked magnets so so, even opened the strainer to check for debree there too. Changed the fluid to the ElsaWins guidelines followed the procedure etc.
    It sat for a month during my leak repairs did the bushes too at the same time after work needed fans too etc
    well i changed the battery and it seems to have solved my issue.
    old battery
    new
    took it for a hard drive and no issues now!
    Nov 21 2018
    Kent
    update - no it did not fix my issue lol
    Nov 21 2018
    Kent
    Desperate to figure this out surely someone's had this ?
