Results 1 to 7 of 7
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Level Control system sensor error
    Hi all,
    I have been getting an Air Suspension system fault that I am hoping to get some thoughts on
    Description:
    - ONLY comes on after about 10-15min of driving at highway speeds (city driving does not trigger this for some reason).
    - Resets after you turn the car off and back on
    - Car feels like its on hard coilovers / shocks when the error is active (back to proper suspension feel once you turn the car off and back on)
    - Came up after sometime after I tried lowering the car 10mm via OBD11. I thought the car was too low so I raised it back up via OBD11 to stock heights. Problem still occurs now
    - Inspected and cleaned all 4 sensors but that didnt change anything
    I did scan it using OBD11 and the error code reads "Level Control System Sensor", see pic below
    Question: any idea what this could be? I know it might be a fault sensor but is there a way to tell which one it would be? any other thoughts?
    Feb 15 2011
    Northern VA
    This happened to me.. I followed the level reset process using vag-com via the link below and it fixed it
    https://www.ross-tech.com/vag-com/ca...elcontrol.html
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by Yeoman View Post
    Thanks for this. Will try out. Did you have the exact same symptoms? Did you also only get this issue during highway driving?
    Feb 15 2011
    Northern VA
    Exact issue and only during highway driving
    Aug 08 2008
    2017 Q5
    Houston, TX
    How did it turn out?
    __________________________________________________ ____________________________
    2016 Aud S7 - Massaging Seats are pretty neat
    2013 VW Passat TDI - Black - sold
    2015 S4 Prestige - DSG - Mythos Black Metallic 2003 Civic EX 5spd - Gone
    2010 F-150 Lariat Super Crew - Gone 1988 Toyota Supra N/A 5spd - Gone
    2008 A4 2.0T 6spd - Gone 1999 Civic EX auto - Gone
    UTSA Alumnus - #BIRDSUP #WBC #GETROWDY
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Okay so update for everyone:
    I followed this procedure below and it now seems that everything is working OK (for now):
    https://forums.ross-tech.com/index.php?threads/12737/
    I did follow almost this exact same process many times before and had no luck with getting this issue gone but without the "Deactivating Loading Mode".
    Thanks for the tips! will let you all know if this comes back.
    Feb 15 2011
    Northern VA
    Good to hear! The error never came back for me
