Been doing some research on the lowest stock springs: 1BV sline suspension. Am trying to get mine lowered another 10mm from 1BE to 1BV springs. Would anyone here know if 1BV is equal to the Eibach prokit springs as per link?
https://eibachshop.com/index.php?p95...i-a7-sportback
Would a kind soul here with the 1BV Sline sport suspension option be able to share you chassis code here so i could order the right parts from my parts stockist? apparently there are too many weight classes of springs that it would be impossible to identify the right spring part number without a full chassis code. Any one with a6/a7 3.0TFSI could help me out?
These come from an A6 TDI, i am not sure if applicable to the A7 3.0TFSI.
S-Line Suspension (30mm drop):
Front Springs (1BV 0JL)
8K0 411 105 CR coil spring, orange/grey/blue/blue (S-Line)
4G0 413 031 M shock absorber, Tenneco (S-Line)
Rear Spring (1BV 0YM)
8K0 511 115 CQ coil spring, blue/grey/green/green (S-line)
4G5 513 035 D shock absorber for sport, 1BE (Sport)
My current codes/options for STRUTS, Front and Rear Springs.
1BE = Sports suspension/shock absorption
0YM = Weight range 12 installation control only, no requirement forecast
0JJ = Weight category front axle weight range 9
