My girlfriend just bought a 2011 A4 2.0T quattro 6-speed. The previous owner said he hollowed out the cat when they replaced the turbo. He didn't live in a county that does emissions. It keeps throwing the P0420 Catalyst Efficiency Below Threshold code. We have to get the car to pass the emissions test (OBD-2 scan and visual) so I was wondering if anyone has passed with a high flow cat and an O2 spacer, or if a high flow cat (USP 200 cell HFC) will cause the catalyst efficiency code still.
I have also seen some cheap cats on eBay for under $150 not sure how well they work. We are going to do an IE stage 1 tune on it and eventually will go stage 2 and that requires a high flow cat anyhow, so I'd rather not buy an expensive $400+ cat unless I need to swap it and flash the car back every damn year to pass emissions. The IE stage 2 tune I believe turns off the rear O2 but I'm not sure if they can tell in the emissions scan as long as the heated O2 and catalyst show "ready".
