    Sep 17 2005
    Fremont, California
    The 034 High Pressure Fuel Pump Piston Upgrade Kit for 2.9T & 3.0T is Now Available!
    The 034Motorsport High Pressure Fuel Pump Piston Upgrade Kit for Audi 2.9T & 3.0T EA839 is erfinally here!
    The 034Motorsport High Pressure Fuel Pump Piston Upgrade Kit is designed to be a drop-in replacement piston for the factory high pressure fuel pump for the 2.9T and 3.0T TFSI EA839 engines found in the B9/B9.5 Audi S4/S5/SQ5/RS5, C8 Audi A6/A7/S6/S7, and 4M.5 Audi Q7/Q8.
    By upgrading the factory high pressure fuel pump with the 034Motorsport High Pressure Fuel Pump Piston Upgrade Kit, the factory fueling limits are raised by up to 37% in 2.9T or 3.0T EA839 engines. This increased flow allows the fuel system to meet the higher demands for ethanol, race gas, more pump gas, and pairs perfectly with all Dynamic+ ECU software that requires an upgraded High Pressure Fuel Pump!
    FEATURES:
    • Yields up to 37% Flow Increase Over the Factory High Pressure Fuel Pump
    • Raises the Factory Fueling Limits Present in 2.9T and 3.0T Engines
    • Increased Flow to Meet the Demands of E85 Optimized Tunes and Turbo Upgrades
    • Required for Most Stage 1+, 2+, and Stage 3 Performance Software
    • Fuel Pump Internals Precision-Machined to Aerospace Tolerances
    • DLC Coated Piston and Cylinder for Reduced Friction and Increased Performance
    • Matched Piston and Cylinder for Absolute Precision
    • Relatively Easy Installation
    WHAT’S INCLUDED:
    • 1x Pump Piston & Cylinder Set
    Note: EA839 High Pressure Fuel Pump Tool is highly recommended for ease of installation
    Check it out here!
    Oct 03 2020
    San Diego/CA/USA
    Will you be offering pre-built or the option to send in our HPFP to be built/tested in the future?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by spacecase View Post
    Not at this time - we are only offering the piston upgrade for DIY at this time.
    -Sean@034
    Junior Member One Ring
    May 24 2022
    Palm Springs, Californuia
    Why doesn this come iwth an upgraded spring like apr. Im unsure what it does but just noticed the difference?!
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by col10 View Post
    In our testing, we found no indication that an upgraded spring was necessary.
    -Sean@034
