Results 1 to 22 of 22
    Junior Member Two Rings
    Apr 29 2021
    2019 B9 A4 Prestige Sport
    Corona, CA
    Chasing misfires, repair or replace ignition coil connector and wiring
    Hi,
    Has anyone repaired or replaced the ignition coil connector or wiring? Mine are so jacked and I have to do something about it but can't seem to find replacement pigtail, or Audi pin connectors so I can run new wire into the connector.
    Is there a vendor that sells a replacement pigtail? Should I try to source the audi pin removal tool, connectors so that I can remove damaged wiring near the connector?
    Any help appreciated.
    Best
    Oct 12 2018
    B5 S4 Avant 2.7t 6MT
    AKA: gjweyman
    Apr 29 2021
    Corona, CA
    Thanks gjweyman.
    However, those are 4-pin connectors and the ones I'm looking for are 3-pin like this used one on ebay https://www.ebay.com/itm/284172704629.
    Was trying to figure out if I can remove the pin and damaged wires on these connectors and reuse my connectors.
    Oct 12 2018
    https://www.prowireusa.com/txl-wire
    If you decide to make up your own, recommend it. You need materials such as Tesa tape, TXL wire, DR25 heat shield, maybe techflex PET sleeving to cover the loom wires, and soldering wires vs butt connectors are less bulky.
    https://www.mcmaster.com/ Has most or all of what's needed too... Look for the wiring diagram
    Sent from my motorola one zoom using Audizine Forum mobile app
    AKA: gjweyman
    Oct 12 2018
    Ok sorry thinking about going to a newer 4-pin coil pack to delete ICM.
    Depin tool https://www.ecstuning.com/b-schwaben...caAq_VEALw_wcB
    AKA: gjweyman
    Oct 12 2018
    The pins may be found here.
    https://www.te.com/usa-en/products/t...s-splices.html
    AKA: gjweyman
    Apr 29 2021
    Corona, CA
    Thank you for taking the time for this info. I really appreciate it. I'm on a mission to replace/repair all the damaged wiring in the engine compartment but want to do it the correct way, or smart way.
    I am also thinking about doing the 2.0 coil swap from ECS which might solve having to rewire these older connectors I hope.
    https://www.ecstuning.com/b-ecs-part...s/002686ecskt/
    Apr 07 2011
    Home of the mighty beaver
    Or you could save yourself time and money https://jaeinnovations.com/products/...wiring-harness also sold on the ETSpec site https://etspec.com/b5-s4-coil-wiring-replacement-kit
    I havnt put mine in yet, but i can attest that its well made.
    then get yourself 6 35usd "rs6" boltdown coilpacks from whoever and complete the kit. skips all the conversion nonsense, failure prone connectors, old wiring etc.
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by SideMirror View Post
    Do NOT solder. Use uninsulated closed or open barrel splices with adhesive lines shrink wrap over. Done right and they arnt bulky.
    I also make coil harnesses with all OEM connectors, Tefzel wire, DR25 sheathing, and a DT connector. Replaces everything from coil to ECU. If interested drop me a DM.
    Here’s pics of some I’ve made.
    **edit**
    I highly suggest buying that tool kit no matter what. The pin removal tools work awesome and the connector removal tool helps prevent breaking the tabs.
    Apr 29 2021
    Corona, CA
    Quote Originally Posted by S4James View Post
    I saw that harness and was reading on the installation which seems fairly straightforward. Is it possible to still delete ICMs if I install this harness or that system stays?
    Thanks
    Veteran Member Three Rings TwoSnelz's Avatar
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    Or you could save yourself time and money.....
    ...then get yourself 6 35usd "rs6" boltdown coilpacks from whoever and complete the kit. skips all the conversion nonsense, failure prone connectors, old wiring etc.
    Highly recommend avoiding the push down coilpacks and stick with the bolt downs like James suggested.
    Sent from my SM-G973U using Audizine Forum mobile app
    Apr 29 2021
    Corona, CA
    DM sent
    Apr 29 2021
    Corona, CA
    Quote Originally Posted by TwoSnelz View Post
    10/4 on that. Thank you!
    Apr 29 2021
    Corona, CA
    more questions as I delve into this engine's wiring.
    This single wire/pin connector is in bad shape. It's mounted below the DV on the driver side IM corner. The wiring is exposed all the way into the connector. How would you go about repair/replacing this?
    Apr 07 2011
    repin with a new terminal.. you can get the premade wires with a terminal crimped on each end from ECS you the cut back some of the offending wire, and using a barel crimp lay in your new section, and insert into the connector.
    Apr 07 2011
    Quote Originally Posted by Ducati899 View Post
    Thanks
    ICMs are eliminated.
    Apr 29 2021
    Corona, CA
    Yes, makes sense. Thank you.
    May 10 2018
    MA
    Fwiw, push down coils (genuine audi, not any rebranded aftermarket) on my car for the last 50k miles (3 years). Zero issues of any kind.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Zero issues here as well.
    Apr 29 2021
    Corona, CA
    Quote Originally Posted by RMode View Post
    Thank, appreciate that feedback.
    - - - Updated - - -
    Quote Originally Posted by CELison View Post
    Thank you too.
    Apr 07 2011
    My pushdowns were great until the connectors melted.. Thats a fault with the materials used in the early conversion kits not the coils... Id rather put the bolt down coils for aesthetic reasons more than anything.
    Apr 29 2021
    Corona, CA
    Hi AZ B5 S4 family,
    Reporting back to everyone on this thread who responded.
    Thank you for helping me sort out misfires my car was experiencing. Yesterday after finally completing all the coil wire and sensor repair/replacements, the car finally has ZERO FAULTS. Had a scare/disappointment on initial startup, VAG started reporting MAF errors, lol. But I saw that I had forgotten one of the clamps on the hose.
    List of repairs
    Basically repaired/replaced all the coil connector wires coming out of the harness. (probably the original cause of the misfires)
    New N75 sensor.
    New brake pump vacuum hose.
    Replaced torn/or old vacuum hoses.
    Cleaned the MAF.
    Drove the car about 10 miles and definitely is a huge improvement. I feel some slight stuttering at 3K when WOT but engine pulls very strongly when driven normal and it seemed to improve as I drove the car more.
    Thanks to SILVEREX for building some pigtails and sending out with connectors.
    Thanks to S4James for the links.
    Thanks to SideMirror for the links.
    I feel much more confident working with wiring now!
    Going to take a short break on engine stuff and focus on restoring the paint job and and wheel touchup.
    THANK YOU AZ B5 PEOPLE
