Results 1 to 32 of 32
    Junior Member Two Rings
    Feb 23 2019
    Pickerington, Ohio USA
    Cool Injector Options for Big Turbo Builds (Flow Tested Data Inside)
    So basically I have not been able to find much concrete evidence as to what injectors flow what amount and what I should use for my EA888.2 BT build.
    In this case I bought about 5 different sets, and sent them to get flow tested to actually find out.
    This was originally posted on another site that has been useful to me but I'll post it here as well, maybe it will help someone in the future.
    Also to pre-face this I am throwing a GTX2871R turbo on my 2012 Q5. (Don't wanna hear "SHOULD HAVE GOT THE 3.0 SUPERCHARGED!!!")
    Below is the data I found.
    0261500076 - Standard Injector Used on EA888.2 Motors (2009-2016 A4,Q5,A3 and others)
    0261500645 - MK7 Golf R Injector that many people say to use when going big turbo. I was dis-satisfied and thought there must be better.
    0261500609 - Audi RS3/TTRS Injector. This is where things start looking promising, significantly more flow than both the MK7R and Stock.
    You'll notice the injector stroke and pulse length are different at each pressure. This is simply how they were tested under a regular Bosch HDEV 5.1 test plan.
    Whats most important is the % difference at each test level between the different injectors.
    I ordered 2 others, injectors for the RS7 motor (these are Continental injectors I found out after ordering so I wasn't going to try them because I heard drive current
    is different), as well as Ford Focus RS Injectors. I have a strong feeling the Focus RS Injectors would flow even more than the RS3's, however the diameter of the solenoid
    cylinder is larger than that of the Audi injectors which would require porting the injector opening to a larger size.
    Hope this helps someone looking to run a big turbo in the future. This was expensive to do, so I hope someone can appreciate the free release of information, and maybe inspire others to do the same
    for the sake of the tuner community.
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by connor123me View Post
    None of these will support a big turbo.
    What you also have to remember with the RS3 DI injectors is that the RS3 also has port injection and the fastest RS3’s are upgrading the port injectors.
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    I wonder how these compare to 3.0T and 4.0T injectors as well as how the spray patterns match up. Would be good to shove some high flow aftermarket injectors for ea888 into 3.0T.
    Feb 23 2019
    Quote Originally Posted by JLAllroad View Post
    Do you have any evidence to backup your claim? I don't see why none of them would work. Have you ever done a BT build on the EA888 motor?
    I am aware of the port injection on the RS3. That is totally irrelevant to the fact that the RS3 DI's are flowing 15% more than the stock A4 ones.
    Seems like you're just here blowing steam. It's well documented that even the MK7R Injectors will do 420WHP which is easily 500CHP on a boss500 GTX2867R.
    Feb 23 2019
    Quote Originally Posted by fastboatster View Post
    From what I can gather (I have spent countless hours researching injectors, spending the $$$$ to buy numerous types and then flow test was a last ditch, however I still don't know everything) the 4.0t and 3.0t both use
    Siemens ECU's with Continental Injectors. These engines (from my understanding) use no MAF sensor, which is why they don't have standard BOSCH MED17.xx ecus with Bosch HDEV Injectors.
    Because of this drive current for the injectors is not the same. I have a set of 4.0t continental injectors, they are not quite the same design and the O ring is a larger diameter than the Bosch HDEV injectors so it will also not fit
    in the same fuel rail.
    So flow testing a Bosch Injector and trying to compare it to a Continental Injector is not going to be easy to do because the desired drive current and such is different for each. Beyond this, the 2 injector types are not interchangeable.
    They simply won't fit.
    Waiting for a Audi Dealership Worshiper with their stock A4 who takes it to the dealership for an oil change to explain to me some random off bullshit that they heard from an Audi Tech to tell me I'm wrong.
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    If you're staying 93oct, r's or equivalent are fine, and can do low blend e a little, but will run out real quick. Mabos are the way if you're gonna run e
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by apeck240 View Post
    Agreed
    Apr 01 2021
    Agreed
    Thank god, I was hoping a guy with a stock turbo and fueling that said the opposite an hour ago would validate my personal experience
    Feb 23 2019
    Shit you got me rolling laughing lmfao
    I will just be running 93 but the motor I'm using I fully built forged rods pistons etc. In the future I may go with an even bigger turbo that's why I wanted bigger injectors. From what I have heard tuning the mabo's is a pain in the ass,
    and very difficult to get cold starts right. At 150bar the MK7R flows ~5% more than stock, and the RS3 ~15% more than stock. I'm thinking this should give me easy headroom into the 550-600hp arena, and if I need more fuel past that I would just get a single port injector and an aftermarket fuel controller to run it. Tuning DI's that flow 40% more than stock is difficult and not something I personally want to do (I do my own tuning in WinOLS with KTAG for Read/Write).
    Flink Films on Youtube has a nice build running the Mk7R injectors and hes sitting at about 420whp I think.
    Apr 23 2019
    CA
    4.0T does use MED17 ecu. I wonder where the electrical params can be found for the injectors, but anyways.
    Apr 01 2021
    550-600 with a boss 500 and pump gas? Good luck. For reference, I'm running that kit at 36-38psi, with e40 and meth and did 480whp. Even crank numbers, that's not happening
    Cold starts with mabos and both pumps upgraded are perfect, but wpt is a fantastic tuner
    Feb 23 2019
    I think you are correct. I remember seeing it somewhere so I combed through my damos and stock files are sure enough it looks like it uses the MED17.1.62
    So only the supercharged 3.0t uses Simos. I would be interested in finding electrical params too. There *may* be somewhere in the ecu code that references things such as this, if I come across it while tuning for these larger injectors I will update this thread with it.
    Feb 23 2019
    No way I do not plan on 600 on a boss500 kit. I was just saying the RS3 injectors *may* have headroom to reach that. I'm also not running a boss kit, it's a custom setup I put together with a GTX2871r which flows a bit more than the 67r.
    I'm looking to run around 500chp daily with what I'm doing, I have a cloned ecu I use for race weekends that I have things such as 2-step enabled on, I just swap between them at events, so I may use my second ECU for high boost and timing to hit 550-600chp if possible.
    Are you using Mabotech Injectors? Also is that 38psi over standard air pressure or 38psi including 14psi background? A 2.6 bar tune seems rowdy as hell. How many g/s airflow are you seeing in logs?
    Apr 01 2021
    Yes mabos, yes actual boost over atmo, near 400gs. On pump I did mayyybe 400whp, you can't have much timing at all on 93, I think peak was 6-8ish degrees. Now with e and meth, 21ish, but like I said you'll need bigger than r's and the 2.5 inj really aren't too much bigger for being double the cost. Like I said, pump r's, e mabos.
    My friend with a 3076 did similar power to me, with 110oct race gas cuz r's wouldn't support e40-50 at that power level
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    i am at 388 whp on 0261500246 (06L906036AJ) injectors can run e30 all day, when trying to run e40 the hpfp cant keep up with the fuel injectors. Have had bad luck with hpfp piston upgrades. Once i get a working upgraded hpfp will see how much the golf r's will support.
    here is an e40 log u can see the hpfp struggling to keep up
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    I'm running Mabo's on my build, with pump gas last it was running. Timing was very low. But, they flow like crazy. I had them cleaned and flowed ... will have to find the results from the bench flow testing.
    Here is the video of the Mabotech injectors being benched after cleaning. https://www.instagram.com/p/CLpSJEplj7-/
    When the build comes back together in the spring, it will have the Mabo's for DI, plus the IE fuel rail with 89lb Siemens Deka port injectors to supplement with the SplitSecond controller to manage the secondary injectors. It will also have upgraded LPFP, HPFP with -8AN feed and -6AN return lines all of the way to and from the LPFP basket in the tank. I'll be running e85 or blended as well to bring timing into the game.
    I'm running a BW EFR8474 1/05 a/r.
    WPT Tuning will continue tuning in the spring to see what we can hit with this setup.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
    Feb 23 2019
    Quote Originally Posted by cybernet99 View Post
    I've been watching your build for a while now, and every time I'm reminded of the detail, quality, parts of your build, and target horsepower my eyes begin to water. I can't wait to see it running.
    If you can find the flow results that would be awesome to see!
    Feb 23 2019
    Wowowow thats alot of boost! And alot of airflow! Very interesting information for sure. So it sounds like I'll only NEED r's but since I already have a set of the RS3's I may as well use them, unless there's a good reason not to.
    Would you be able to share a log from a pump gas tune? Would be helpful for me for aiming the tune for mine here shortly.
    Apr 01 2021
    What would you be looking for specifically. And you're gonna want e to get even near your goal, so I stand by my mabo suggestion, as far as flow, I can tell you I'm running a lowered hp pressure, 135 bar, just to get some inj duration because they flow so fuckin much. Do you want stock fuel system logs, or current (mabos, autotech piston, aem 340, 380cc meth). You're gonna hit the same problem I did if you're only running 93, the stock stuff held up quite a lot, by the time I did fueling mods I only gained like 5% power, but had a fuel system to make like double the power I could on 93. Then you'll be looking at ethanol, a bigger turbo, etc etc
    Apr 01 2021
    Feb 23 2019
    Stock fueling on the boss500 would be a good start. I'm going to tune that first. I do have a 034 hpfp upgrade in though. I also do not want to run ethanol as it isn't practical for me to daily on it where I live. I ran methanol injection daily for the past year so that is something realistic for me. I buy about 50 gallons at a time. So logs from stock fuel system and a daily tune with the mabos would be excellent!
    Feb 23 2019
    WOW, you got any videos of this thing?
    Apr 01 2021
    Stock fueling, last file before mabos I believe, you can see em struggling and running no fuckin timing on pumpstocklog.jpg
    Feb 23 2019
    Is there a way you can export it so it can be viewed in datazap? It's alot easier to read! 4.5 is not alot of timing for sure
    Apr 30 2018
    DFW, TX
    https://www.facebook.com/groups/7158...8555670518092/
    - - - Updated - - -
    WPT+
    Dec 03 2015
    Marseille France
    I'm on Mabo's also, after 37 revision of tune they now have perfect cold start with 100% E85. Feel like OEM on any percentage of throttle
    Only thing MPG seams to go down with those. not easy to get fine spraying accuracy for light throttle when your injector flow like fire hose.
    I thought I had trouble with those at one stage but in fact it was the inside gasket of the HPFP that was dead and my VIS got scratched from that.
    Now with brand new HUCO HPFP (Huco = Hitachi Germany) and 034 Kit it's perfect.
    Feb 23 2019
    Quote Originally Posted by Mars2 View Post
    Who did your tune for you?
    Dec 03 2015
    Marseille France
    I'm in France So will not help you to give you my tuner.
    If I was in USA I will 100% go for WPT
    Oct 15 2022
    Nassau Bahamas
    Do you guys have a part number for the Golf R injectors?
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Quote Originally Posted by IslandA4 View Post
    026150001H. I think this is right.
    Sent from my SM-G973U using Audizine Forum mobile app
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    06L906036AK is the latest revision.
    Oct 15 2022
    Nassau Bahamas
