Results 1 to 11 of 11
    May 17 2014
    SF Bay Area
    Possible to run 305 tires on 22x11 wheel?
    Hey all. I just ordered a set of 22 x 11 wheels and I am wondering if I can run a 305 tire at stock height without rubbing? If so, can it also be run if the car is lowered? Or does it depend on the offset of the wheel? This is on an RS6 and I was told I should buy a 295 / 30 / 22 but tires are very limited in this size so looking at dropping down to a 285 or moving up to a 305.
    Thanks in advance.
    Established Member Two Rings WTF its Arturo's Avatar
    Jun 08 2011
    C8 RS6, B9 SQ5, B7 RS4
    Paging Martin...
    Depends on your offset, but 305/30 can be done on a lowered RS6.
    Garage
    Ultra Blue RS6 | Sprint Blue RS4 | Ibis B9 SQ5 (wifey)
    IG: @rs.turo
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Quote Originally Posted by s4thrills View Post
    Thanks in advance.
    Is currently being done (stock height and lowered) and most definitely depends on offset.
    Veteran Member Three Rings rusq5's Avatar
    Mar 26 2015
    SF Bay Area
    Thanks in advance.
    I've found 305 has even fewer options than 295. If you find somewhere that has PSS in that size and in stock, hit me up.
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    May 17 2014
    SF Bay Area
    Quote Originally Posted by rusq5 View Post
    Interesting. The reason I was asking is because Michelin makes the PS4/5S in 285 and 305, but not 295 as far as I could tell on their website tire finder. In a 295 they don't give you the option for a 22" wheel. Only tire I was able to find in a 295 was a Continental which aren't bad but I love my PS4S.
    May 16 2007
    Ottawa CA / DE USA
    Haven’t seen PS4S in 305, only PSS. PSS 295/30R22 have been discontinued hence why I’m running the 305.
    May 17 2014
    SF Bay Area
    Quote Originally Posted by Jimminez@Nemesis View Post
    Yeah, my bad... just realized it was only the PSS in the 305 size. What other tires do you recommend in a 295? Is it only the Conti?
    May 04 2022
    2022 C8 RS7, 2021 GMC Denali, C6 Corvette vert, 2017 Q60 Infinity , Silverado 3/4 ton p/u
    Iowa usa
    I’m running the Conti 295’s on my 2022 RS7 and really liking them. Just got back from a 4 day rally with a lot of mountain type roads and they handled great. Lots of hard turns at speed. I will get them again when the time comes.
    May 17 2014
    SF Bay Area
    Quote Originally Posted by Gman57 View Post
    Thank you! This is good to know.
    Mar 26 2015
    SF Bay Area
    I’ve been impressed with my set as well. After running PSS and PS4S for years I would say they are 80% of a ps4s. I’m not a huge fan of the road noise, but they nearly as sticky as the michelins
    May 16 2007
    Ottawa CA / DE USA
    Pirelli has PZ4 in 295 which is same tire as OE 285. Toyo has something in 295. Both run skinny.
    Grey market (EU) has more options and still list MPSS.
    https://www.reifendirekt.de/cgi-bin/...=Reifen+finden
