I had the JB4 on my 2020 8V RS3 and loved it. When I traded the car in for the 2022 RS3, I took out the JB4 and planned to install it on the new RS3. With all the bad news about the new 8Y's not being tunable I held off installing the JB4, but have been in contact with George at Burgermotorsports.com on a pretty regular basis to stay up on when the JB4 would work on the new model. George now tells me that they are finally shipping the SENT unit with firmware allowing up to MAP 3 configurations (93 octane).
Here is George's response:
We are shipping the Group 9 SENT unit to customers with firmware that works up to map 3. It is the unit that is found here:
https://burgertuning.com/collections...9-jb4-for-audi
The Vin recognition is not working on all models so if at idle you are not seeing rpm moving in the display of the app you will need to do a settings change that I have outlined below.
Alternatively I can let you know once we are completely done with the unit.
Currently we limiting the unit to map 3 which is good for 93 octane fuel . With the next update more power can be released but this is good for around 60hp and 55ft lbs.
My app looked slightly different but a quick reply from George and I did the following:
Click Bit 5 to "ON" then hit SAVE.
I had no trouble installing the JB4, same procedure as on the 8V, harnesses are the same, but one thing to note is the 8Y has an insulation pad on the outside of the firewall in the engine bay that covers the pass-thru hole in the firewall. I popped off the little egg-shaped grommet that covers the hole and it was easy to snake the OBD wire down and out thru the firewall. I plan on a few pulls to log some data but for those who have the JB4 and wondered if it would install in the new RS3 it does. Give it a shot.
