Results 1 to 14 of 14
    Junior Member One Ring slava's Avatar
    Oct 21 2022
    2023 A4 45 Premium Plus - Missing features?
    Are these features no longer included or should I go RTFM?
    My trunk doesn’t open by foot and the cluster doesn’t show any road signs.
    I went thought every menu item in MMI and didn’t see anything.
    Also, is there a way to disable car WI-FI network from broadcasting?
    Thanks,
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Baaed on my reading of the USA 2023 Audi Order Guide, with Premium Plus you should have the hands-free trunk release (ie foot activated) but needed Prestige for the Traffic Sign Recognition.
    If you PM me with an email address I can send you the .pdf of the 2023 Audi Order Guide.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Oct 21 2022
    Ah, i found the guide. Thank you.
    PPlus does seem to include "convinience package" - but now i need to figure out the features included in it.
    Traffic sign recognition does seem to be a Prestige thing, but my cluster has "traffic sign recogniztion" and that thing never seems to work in my area.
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    Also take into consideration that the unavailability of chips which may control some items (like blind spot monitoring) can cause items to be missing from certain accessory packages. Check your build sheet/sticker for credited items.
    2018 A4 2.0T QUATTRO S-Line APR Stage 1
    PAST: 2015 A3 2.O T Quattro
    2008 A4 2.0T Quattro
    2006 Mazdaspeed 6
    2003 Acura CL Type s
    1999 Acura Integra GSR
    and the list of many Honda products before that.
    Oct 21 2022
    I don't think either is listed, so i'm just gonna accept they aren't included.
    Jul 16 2018
    Atlanta
    Traffic sign recognition has been a Prestige feature the entire B9 run.
    The order guide appears to have never called out the rear lid kick release function as a feature. Maybe it's just considered basic equipment for the US. You could look inside the rear bumper cover just inside of the left exhaust and see if the control module is there. Or see if the J938 shows up as a LIN slave for the J393 (address 46).
    Here is that section from a scan of a 2023 A5 sportback in the Ross-Tech forums:
    Address 46: Central Conv. Labels: None
    Part No SW: 8W1 907 064 DC HW: 8W1 907 064 C
    Component: BCM2 MLBevo 044 0604
    Coding: 013463004FB100C0650BA0006C01080203034000810426502F 0400000F04803F001E0681000F31
    Shop #: WSC 06335 790 00001
    ASAM Dataset: EV_BCM2HellaAU736 020017
    ROD: EV_BCM2HellaAU736_020_AU49.rod
    VCID: 81546B1281F7E8E368D-81D4
    1 Fault Found:
    65673 - Sensor for Rear Lid/Hatch Opening
    B1303 4A {009} - Incorrect Component(s) Installed
    So did it come from the dealership that way? Is this the exhibit of "yeah, we don't have the parts". Are they going to fix it? Etc. What did your dealership say when you asked about the kick not working?
    Oct 21 2022
    Quote Originally Posted by Smac770 View Post
    1 Fault Found:
    This is actually funny. Gotta be a trend with "pandemic" cars.
    I haven't brought it up to them yet. It wasn't on my mind until recently. Until i joined this forum to be exact, i wouldn't even know about it :)
    Senior Member Two Rings northnj's Avatar
    Aug 14 2007
    2023 Panda A4 Allroad
    Wash, DC
    I am dropping off my 23 a4 allroad prestige tomorrow at the dealership to diagnose the kick to open feature. I am sure it was never installed and nothing was mentioned, or credit noted. I'll add to your thread if I have time tomorrow afternoon.
    Sep 10 2022
    Milwaukee
    I haven't been able to figure out the kick sensor either on my '23 A4. I just figured it wasn't a feature, unless I'm not putting my foot in the correct area.
    For the traffic sign function, I was hoping it could be enabled with ODB11. It sounds like it uses the camera behind the rear-view mirror and requires the Navigation package, so perhaps it could be enabled on a P+ with them. Hopefully somebody can figure it out.
    Sep 28 2007
    Mirror based front facing camera is absolutely needed for traffic sign recognition - it's relatively obvious - a trapezoidal like opening in the mirror stem portion that sticks to the glass in addition to a small round circle which is the rain sensor.
    Kick activated truck release - look behind the rear bumper diffuser and see if you can see/feel a sensor or wires - stand about 18" behind the bumper and do a slow kick movement underneath it. For me, it has to be slower than one would expect movement as the sensor doesn't get triggered by fast movements.
    Advanced key needs to be with you and fob battery must be in good condition. Also in the MMI, make sure the trunk lid handle is not in disabled mode.
    Current:
    Jul 18 2022
    I was under the impression both power tailgate and kick open are standard on the A4 and A5, but I might be mistaken and it only may be on the latter.
    Jul 16 2018
    Atlanta
    I remember some of the threads saying you have to kick and them move towards the trunk. I guess maybe it's trying to prevent random opening such as by a small animal.
    Established Member Two Rings cameraz's Avatar
    Jul 15 2008
    Massachusetts
    A small animal is not going to accidentally open the trunk unless it's got your key fob in its pocket!
    Jul 16 2018
    Atlanta
    Pack of ferrets. :-)
