Was on the way back from a 4 hour trip and engine stalled out on the at low rpms on the highway. Pulled over and tried cranking over engine and couldn't get it to crank. Starter just does a small crank, kind of like when you have a weak battery. Pulled out VCDS, no fault codes, battery voltage is good. After doing several more attempts to crank I finally got it to crank over and it ran fine. Drove it to local auto parts store to get battery tested and everything checks out good. Only thing I can tell that is wrong is I have no A/C now. I am wondering if some how the compressor was seized up which stalled the motor, and then cranking it over enough times with the starter broke it free. Anyone ever heard of something like this happening before?
