New to the Audi game but I have had a few volkswagens . I have rebuilt a few vw tsi and fsi 2.0t motors. I recently bought a 2010 Audi A4 that had p0016, misfire codes, rpm lower then expected, violently shaking ect. It almost sounded like the camshaft bridge screen was missing. Did a compression test and every cylinder was 180+. Engine is the factory engine with 104000 on the dash.
I took the camshaft bridge off and found the screen to be missing. I thought maybe it could of went in the oil galley hole so I removed the cradle and cams. I blew compressed air the the holes and couldnt find it. I replaced the timing chains and guides as well since the camshafts were out.
After all of that I’m still getting the same codes and problems. The timing is 100 percent correct(possible the intake phaser is bad?). Lined up the links with the chain and spun it twice. I even made marks with a marker so I don’t have to keep spinning it till the timing chain marks line back up. The p0016 code comes right back, engine shaking violently, check engine light flashing, misfire codes ect.
Checking the scanner data with my snap on scanner the intake cam is at 28 degrees and the specified value is the same at 28. The magnet works when activating it, the oil control valve pushes in and out like itssuppose to. I can’t watch any data on the exhaust cam because there is no sensor. I did find that this engine has a oil control solenoid near the oil pan. I couldnt find any information about this solenoid or how it works. I removed it and no oil came out. I’m not sure if oil is suppose to come out. The tsi vw motors donÂ’t have this solenoid.
That only thing that comes to mind is that the intake camshaft phaser is bad or it’s a oil issue. The p0016 is the main reason for the engine problems and the rest of the codes. Monday I will measure the difference in the cams and report back. I’m just wondering if anyone can help out. I dont have a vcds but I do have a snap on scanner with expert mode. I can go to basic settings and what not. Is there a group where I can see if the cam timing and crank timing are off?
