Results 1 to 40 of 52
    Senior Member Three Rings Jimingle10's Avatar
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    High Mileage 3.0T Thread
    Looking to compile a list of the high mileage cars similar to the C6 forum. I'll start!
    1. Jimingle10 - 2012 A6 Stage2 @ 262,000 mi
    2. ValpoA7 - @ 228,000 mi
    3. gusto11071 @ 203,000 mi
    4. Sepheroth @ 170,000 mi
    5. Jay F - 2013 A6 @ 169,000 mi
    6. Dutch_A6 - 2012 A7 @ 167,000 mi
    7. Havok @ 155,000 mi
    8. ActiveMonkey - 2016 A6 @ 119,000 mi
    2014 RS7 Prestige - Suzuka Gray
    - OEM Options: Exclusive Pkg, B&O, Dynamic Pkg, Innovation Pkg, Driver Assistance, Soft Close
    - DS1 Stage 2 w/ Custom (KYLETUNEDIT), TCU Tune, Meth, E85, TGK Intake
    2012 A6 3.0T Prestige - Black
    - Jackal Stage2+ E40, 196.5mm/60mm, Merc HX
    - JHM Baffled Test Pipes w/ X pipe and HFC.
    - Westfalia Tow Hitch
    *SOLD*2012 A6 3.0T 270k mi & 2017 Q7 Prestige & 2005 A6 4.2L
    2011 Suzuki Hayabusa
    Sep 16 2020
    West Michigan
    ValpoA7 has somewhere around 220k miles.
    I have 170k.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    About 223k right now for me. Was gonna sell but after our Wrangler got hit ($17k) and we need a new roof soon we decided to keep the A7 until at least spring/summer 2023. Need to fix a fault, bank 1 intake runner flap stuck open; did not get something right after doing the t-stat. I will do the PCV when I pull the charger back off. I need to fix a broken wire for the backup speaker. But otherwise not much else to do on it other than the 10k oil change which I will do when I do the PCV.
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    could be the vacuum hose that connects to the intake manifold flap controller thing. my bad don't know the name. Either that or the flaps just need to be adjusted. Either way, easy fix
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Nov 27 2018
    Valparaiso, IN
    Yeah I checked all the connections at the back of the SC and all were good. I read about getting the secondary air tube slightly off location. Not totally worried about it at the moment. Fix it when I do the PCV
    Junior Member Two Rings
    Apr 27 2022
    Brewster, NY
    Dont forget the dipstick mod from the earlier 3.0T so you can actually measure the oil. Part #06E115611H
    https://www.amazon.com/dp/B0BFWNQQJK...hk_typ_imgToDp Amazon
    Apr 27 2022
    Brewster, NY
    Sorry mine has 203K and two PCV valve replacements and still burning oil, or loosing oil from somewhere no leaks or drips.
    Oct 20 2021
    Bulgaria
    I was wondering has anyone changed chains/tensioners or had problems with the cats ? Just curious ?
    Sep 16 2020
    West Michigan
    Quote Originally Posted by gusto11071 View Post
    The belly pan is capable of holding an astonishing amount of oil before dripping to the ground.
    Quote Originally Posted by NikolaZ View Post
    ValpoA7 has replaced chains somewhere over 200k.
    I gutted my cats when I removed them to fix a broken flange. They were showing the beginning stages of meltdown. Single pulley for approximately 20k. (tuned/pulley at ~150k, cats gutted around 170k)
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    I've been stage 2 (single pulley) since about 55k, now 232k. I tow things with my A6 as well, fishing boat and utility trailer (wood, riding lawn mower, motorcycle etc) I have a fair bit of chain rattle and some oil consumption but nothing alarming. I also drive the car hard.
    Biggest maintenance items for me have been
    Flex pipes
    Steering wheel/column lock module (car was inoperable, tow)
    Thermostat and crossover pipe & pcv stuff under the supercharger, it was leaking a lot of coolant. (tow)
    Inner cv joints, aka, front axles.
    Electronic motor mounts
    Oddball /annoying items over the years:
    Fuel injector oring - fuel was gushing out of one (tow)
    Bunch of wheel bearings
    Bunch of spark plugs, only 2 coils
    Aux hvac pump, driver side wouldn't blow heat
    Factory amplifier died (non bose)
    Carbon canister in fuel neck (haven't fixed yet)
    I'm still on a lot of original parts
    Starter, alternator, BATTERY
    Never have I serviced the transmission in any way.
    No differential services
    By far the most reliable and enjoyable car I've ever owned.
    Sent from my SM-S908U using Audizine Forum mobile app
    Veteran Member Four Rings quattroism25's Avatar
    Jun 04 2007
    Exiled in Utah
    I recently sold my 2012 with 206k. Had to change the pcv at around 150k and carbon cleaned it while I was in there. The car ran great for up to 200k when it started burning a little oil from the rear main seal. Repair cost wasn't worth keeping it then.
    Daytona Grey S7
    MORO BLUE JHM modded V8 Sold
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    2012 A7 sitting at 167k, preventative maintenance over the last 15k has been replacing water pump, PCV and thermostat, valve cleaning at 150k, set of spark plugs and a transmission service. Been tuned since 100k going from stage 1 to currently dual pulley and ported blower
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Nov 27 2018
    Valparaiso, IN
    Quote Originally Posted by Audibellybutton View Post
    I think I have it fixed. Now to drive around and see what happens. The secondary air hose that routes past the actuator was routed too close and had a strangle hold on the actuator. Took the hose loose and moved it about 1/4 inch to free up the actuator. I was surprised to be able to access without removing the SC
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    Bump for 244k today and still going. Should see quarter million soon enough.
    Also bought a 2014 RS7 this week to um...keep the miles off the A6 :)
    Oct 20 2021
    Bulgaria
    Jimingle10 have you changed the chains yet ? OR just keeping with the initial rattle if you have it ?
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    Full send baby! Original battery to my knowledge too lol.
    I will hit 250k this month
    Nov 27 2018
    Valparaiso, IN
    I am in the 228,000 range at the moment. She just does not get driven like before. With the work commute I was logging 35,000 or more miles per year. Now I barely do 10,000 miles a year. And we take the new to us Wrangler JLU for our usual errands most of the time.
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    Quote Originally Posted by Valpo A7 View Post
    Not putting milage on it keeps you from having a payment
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    You guys are making my car feel young. I bought it 9/2022 with 82,000 and now I'm ~119,000. I average 50-60k miles per year so I imagine I'll catch up to you folks pretty quickly.
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
    Oct 20 2021
    Bulgaria
    50-60k a year is like oil change every month.
    @Jimingle10 that sound really nice. Just left my Q5 3.0T for upper tensioners change and I guess that is the last thing I will have to do in the near future.
    Nov 27 2018
    Valparaiso, IN
    Quote Originally Posted by ActiveMonkey View Post
    You guys are making my car feel young. I bought it 9/2023 with 82,000 and now I'm ~119,000. I average 50-60k miles per year so I imagine I'll catch up to you folks pretty quickly.
    How did you manage to buy your car in the future?
    Jan 27 2006
    Orange County CA
    Yes sir. The use of an oil extractor makes changing the oil stupid easy and quick. No need to even get under the car.
    I went 88mph in my B5 S4 straight to carmax
    Nov 27 2018
    Valparaiso, IN
    Jumpin JIGAWATTS!!!!!
    Jan 29 2019
    St. Petersburg, FL
    2013 A6 here that i bought January 2019 with 98k miles from a single owner. I'm now up to 169k miles with no major issues. Car does love to eat control arms even more than usual though after lowering, Bilstein b8 w/ H&R springs
    Quote Originally Posted by sepheroth86 View Post
    I noticed this last weekend when i was replacing my front rear lower control arms. Noticed that the belly pan and lower engine components were fairly wet, although it didn't look fresh, so could be from small spills over the years too. However i am burning about 1qt every 2-3k miles. Nothing crazy, but i have already replaced the PCV and also don't see drips anywhere else. Where did you find your leak was coming from, any common areas? I guess perhaps rear main seal like a lot of other cars?
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    1qt every 3k miles isn't enough to warrant a red flag from my experience. Mine consumes about the same especially with a lot of spirited driving. I do get a puff of smoke at high rpm. I wouldn't say it's "normal" but it's fine.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    wowza
    Jul 15 2015
    2000 Z51 Corvette 427, 1987 AM General M998, 2013 A6 Prestige APR Stage 1 (RIP)
    Boston MA
    155k miles with a stage 1 APR and no issues until a week ago. Got check engine light so I need to pull the codes and see what it is when I do my oil change. Being good weather I can have it in the garage and drive something else and take my time with whatever the issue is. I'll report back in if its something major.
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Quote Originally Posted by Jimingle10 View Post
    Wow! Have you had any major engine services/surgeries? Timing chains/tensioners/guides?
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    Nope. Water pump / pcv / thermostat etc was the biggest engine service
    Apr 27 2022
    Brewster, NY
    Motor Died @ 207K replaced with a 98K ENGINE from salvage yard, also replaced water pump, timing chain, all belts , also retrofitted the PLASTIC valley pan with the METAL one from a 3.2L VR6, no more taking out the supercharger just to replace the PCV also, added a JHM 207MM single pulley stage 2 tune from iE , a 4.0T heat exchanger, 2.75" Full becker exhaust, RS5 Mufflers , 80MM throttle body, 1360MM supercharger belt, etron CWA-150 auxiliary water pump.
    Dec 04 2019
    West Chester, PA
    What happen?
    2007 Toyota corolla
    Nov 27 2018
    Valparaiso, IN
    230,700 miles on the 7 at the moment . My grill chrome is starting to unlaminate and I am considering a replacement grille. The question now is stock slats or RS7 honeycomb pattern. I don’t have any tech items to worry about if I swap to the honeycomb.
    Or just spend the money on some more 5.56 ammo and not replace the grille
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    I reload so I don't have to make tough choices like this! This weekend was 6.5 Creedmoor, .223Rem and 338 Lapua Magnum. Saved a ton of $$!!
    Cheers,
    KS
    Aug 31 2011
    Lathrop
    Apr 05 2007
    Tell me more about this metal valley pan, please. Did you do that with the Merc PCV relocation kit, or does the 3.2 metal pan allow you to rerun/reconfigure things itself? Do you mean the 'regular' 3.2L V6 (vr6 is staggered inline, right? too narrow for our "v"?)
    today: 2016 A6 Jackal Stg1 E85
    yesterday: 1990 Audi 90 Quattro, 2x B5S4, 2 x B5A4, 1xB7A4, 1x C5A6
    Junior Member One Ring
    Sep 23 2023
    Dallas Texas
    Had 168k on my 2012 A6 that was running a STG2 dual pully tune for the last 50k miles before an inconsiderate 2002 Jaguar tboned it. I regularly dogged on it and took it to a local drag strip 1-2 times a month and would do 5-6 runs a night when I did. Never had a single issue with it. Same thing with my old S4, Sold it at 170k with a stage two tune and stock heat exchanger, new owner bumped it to e40 2+ still running a stock intercooler (that had had a rock chip that was welded shut) and has put at least 10k more on it and she's still running great. Very reliable engine.
    2015 Audi S6
    (WIP) 2013 Audi A6 with 034 HPFP piston APR dual pully, Merc Racing 4.0T Radiator, CAP Test Pipes, CAP Non-resonated Midpipes, ROC Euro Intake 034 Stage 2 Crackle Tune, 034 ZF8 TCU Tune
    (RIP) 2012 Audi A6 with APR dual pully, Merc Racing 4.0T Radiator, CAP Test Pipes, CAP Non-resonated Midpipes, ROC Euro Intake 034 Stage 2 Crackle Tune, 034 ZF8 TCU Tune
    (Sold) 2013 Audi S4 with APR dual pully, JHM Test Pipes, 034 Stage 2 Crackle Tune, 034 Stronic 7 speed TCU Tune
    Nov 27 2018
    Valparaiso, IN
    This will be my last week with my A7. Trading it in on a 2015 Maserati Ghibli with just 13,000 miles on it. Took out an extended warranty with it as well, 5 year 60,000 mile warranty.
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    Hope it's a good one! Seen Doug demuro review one and it was no bueno. Sexy car though, good luck sir!
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    Updating my own post -
    A6 is at 262,000 miles, valve covers been weeping for awhile, getting aftermarket covers and new gaskets next week.
