Results 1 to 14 of 14
    Junior Member Two Rings
    Mar 11 2014
    RS5
    France
    Advices for removing perfume odor from cabin interior
    Hello,
    I need your help for neutralizing a perfume odor in an Audi B8. Maybe it's not the best section but it's for this type of car.
    Someone did use in the car a perfume scent and it is everywhere in the car.
    Does someone has an advice to totally neutralize perfume sent ? Or a product eg. whole cabin spray mist.
    I've read that you can use baking soda, white vinegar etc.
    Any help would be greatly appreciate, thanks.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    Funny but I've got the same issue. Vented the car for over a year. '13 RS5, I think a Stripper owned it, cheap perfume smell and there was glitter all over :)
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    Quote Originally Posted by hahnmgh63 View Post
    Should have gotten a "special service" from her as part of the purchase package.
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    I would expect it to be in the soft surfaces, so I'm thinking you'll need something to extract it.... I'm thinking a steam cleaner, much like a detailer would have\use
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Use or rent an air ionizer. You can use a big home model one and just shut the doors. Leave it in overnight and should remove all smells.
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    Buy one of these, and leave it in the car for a week. Worked wonders on a car I bought that had a musty smell, also with my damp basement.
    https://www.amazon.com/dp/B0821SWJ5S...6-76d57e86a54b
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Jul 31 2011
    Quote Originally Posted by Brozee View Post
    I like the product, but.... a week? My car is used almost every day, as I expect is true for many of us. Maybe the option for me (and others) would be to put it in overnight, every night, for a week or two... I could probably use one in my home office as well....
    Thanks for the link Brozee!
    Oct 12 2009
    Oxford, MI
    Quote Originally Posted by papadelogan View Post
    You can use your car… just leave it in there for a week :)
    Mar 11 2014
    RS5
    France
    This is funny as hell !
    Thank you all for the advice. I've been to a detailer and he said some people do come by with the same problem and that he would never use cleaning products with perfume. At the shop there is some kind of big machine that he leaves in the car to remove all sorts of odor. It could be as said here a de-ionizer. He said that the machine will leave some kind of other odor but ultimately goes after some days.
    What does frighten me is that perfume is petrochemical stuff. Sometimes even mixed with silicone oils so I'm not sure a part from mechanical cleaning or chemical decay solutions how it could solve the problem.
    Junior Member One Ring
    Apr 26 2022
    Vancouver,BC
    Aug 30 2016
    Los Angeles, CA, USA
    +1 on the ozone generator.
    Mar 11 2014
    RS5
    France
    A little feedback, tried as advised a ozone generator :
    https://www.amazon.de/-/en/gp/product/B09MFQZ29Y/
    Incredible ! Left it only 10 minutes to try it inside the car. Then let 1 hour the ozone to do its job then vented all the night.
    Odor is absolutely NON EXISTENT now. Unbelievable. The smell was so strong I thought it would be impossible.
    Thank you all so much !
    Veteran Member Three Rings mikedizzzo's Avatar
    Nov 03 2016
    So Cal
    Put coffee beans in the car
    -MikeDizzzo
    2016 S5 Premium Plus | Florett Silver | Black Optic Plus Package | DSG | ADS | Carbon Atlas | B&O
    Mods: GIAC Stage 2 | TCU | SC Pulley | Bilstein B16 Ride Control Coilovers | AWE Touring Exhaust 90mm | Maxton V1 Front Lip | 034 Transmission Insert | Brakes - Hawks Pro with slotted/dimpled rotors | Relak Paddle Shifters | Ceramic Pro 9H | LED interior | 2 x Audizine 5' stickers | Audi All Weather Mats
    Active Member One Ring DemaLoher's Avatar
    Nov 21 2022
    USA Kansas
    Hey, I've also been there recently. Here are some tips:
    First, try airing out the car by opening the windows and letting it sit for a while.
    Try using baking soda or activated charcoal to absorb the odor. Sprinkle some baking soda or place some activated charcoal in a bowl in the car overnight and then vacuum it up the next day.
    Another option is to use an odor-neutralizing spray specifically designed for cars. You can find these at auto supply stores or perfume stores like DecantX.
    I hope these tips help you eliminate your car's perfume odor. Good luck!
