IMO, I had the hardest time with this, especially with the factory dampening on my current car, I can't imagine it's much different with the RS3.
The springs and shocks are so dialed in for each other, it's really difficult to get low and comfort in the same sentence.
One major thing I would say is investigating how to recalibrate after a drop. That was a major difference that I found after lowering my VW anyway. Pretty much you need all 4 wheels off the ground, and of course leveled. Then in OBDII you can re-calibrate.
Other then that, I tried EMD springs, MSS adjustable springs and finally Eibach's.
I loved the EMD springs drop, the ride was good in 80% of the situations, but out of the blue you would bottom out the shock and you were afraid of how much that is going to cost. Only to learn you are simply putting daggers into your shocks life.
With MSS springs, they were good, but it seemed the product wasn't too good and initially they handled great and seemed like the right product. I ended up replacing two blown shocks from the EMD's and MSS's with Bilstein's only to make the issue worse. I tried adjusting, but keeping in mind, as you adjust the springs - you should also consider an alignment when you have it dialed in where you want it. That being said, something that is easily adjustable is important which I always had a hard time finding.
It wasn't until I got the Eibach's, where the ride height isn't as low as I wanted - but the ride quality paired with the Eibach B6's - is just an absolute blast. Comfort is comfortable, while race it feels like you can't find the cars limits without having a level of crazy.
Morale of the story:
OEM = light drop
Bilstein B6 = light drop
Bilstein B8 = drop away, and I think this is where I would put adjustable springs too...I am not sure if I would do adjustable springs again, MAYBE a different product then MSS Springs
Just buy, coil overs, and I think Bilstein B16's were what I wish I bought instead of going the Eibach / B6 route. The dampening adjustability with the 8Y RS3 and MK8 Golf R, is going to be more interesting though, as you have a lot more play with settings.
Again, lessons learned on a Golf R...not a RS3...but this is the first thing I am working on when I get my 8Y
