I have had a coolant leak and a P2181 code recently. Checked the leak, coming from water pump. No problem, I replaced the water pump AND thermostat last weekend. STILL getting the p2181 and the coolant temp gauge is not getting up to the middle line, just like prior to the replacement of the water pump and thermostat. Check VCDS under IDE04083 (Coolant Temperatures) it reads: ETC 1: 65C, ETC 2: 98C.
Seems to me like either the thermostat I just installed has already failed, or that my one coolant temperature sensor has failed. Since I was getting the code with both the old and the new thermostat, that would lead me to lean towards the sensor.
Can anyone pitch in as to how I can test the CTS? Is there a mistake I could have made installing the new thermostat that is causing it to stick open? Every thread I read seems to point to thermostat but I just replaced that part. A bad CTS right there on the front of the engine would be much easier to replace. The part I installed in my 2013 S4 was the Rein CTA0017 which I purchased from FCPeuro.
