You cannot clear a permanent code with a scanner or battery disconnect. I suspect if people are doing it with HP tuners they are clearing and reinstalling the ECU file. That might do it but it's not necessary.
You can pass a CA SMOG check with a permanent code in place as long as you have these items in place:
No Check Engine Light
Monitors Complete (Except for EVAP, that can be incomplete)
And this is the important part: Driven 200 miles and have 15 Warm Up cycles since the last time the DTC's codes were cleared.
See here:
https://www.bar.ca.gov/Industry/PDTC
Now doing this 200/15 task will not clear the Permanent code but rather the CA SMOG machine has been programmed to ignore the Permanent code if 200 / 15 is complete.
Warm up cycles are simply the engine getting up to a normal operating temperature then cooling back down below a certain temp. Not sure what those numbers are in an Audi. Below is a video of a guy forcing them on a car with a fan to aid in cooling things down. This can be done in your driveway if you want.
Permanent codes are a new thing is 2010 and newer vehicles so folks are not up to speed on them yet. With the check engine light off and a permanent code present does not mean there is anything wrong with your car. It means there
WAS something wrong with your car and those codes are going to stay around a while to make sure you fixed it right.
If not for a CA SMOG you can basically ignore Permanent codes they are not hurting anyone hanging around inside a ECU.
https://www.youtube.com/watch?v=gswP3KlmfdI
