I am not retrofitting rather I had a minor fender bender that smashed driver side OEM LED headlight assembly. Water got in and fried the control module. I replaced the LED DRL module before and this was no issue but after replacing assembly and module low beam works again and hi beam works on right side but hi beam on side w new assembly and module does not work and cornering lights not working . Still have error message in display about adaptive lights and OBD 11 reports module needs re coding . The module is brand new. I searched everywhere and I'm only seeing coding options for VAG COM which don't transpose to OBD 11 from what I can gather. Can someone help me with the long coding and/or simply help me clear the error code which will then allow for the cornering lights and driver's side high beam to work again? It's a 2016 pre face lift (8v) S3 Prem Plus with all LED option. I am happy to provide any additional info that might be needed. Thanks in advance.
