Originally Posted by
jco897j
Is it possible to replace the pulley and clutch assembly without just replacing the whole compressor? I've got an awful noise coming from the front end that I think I've narrowed down to the compressor area. Car runs and drives perfectly normal. AC blows fine. Just a nasty intermittent grindy noise that seems to be coming from the compressor pulley. Ideally I'd like to replace just the compressor clutch and pulley assembly.
Sent from my SM-G986U using Tapatalk
The hub of the compressor is just a fixed pulley, it's not a clutch. For all intents and purposes, the compressor is "always on". The pulley has some thin points in it's construction that shear incase of compressor lockup to prevent the belt from burning off, but other than that it's a fixed pulley with no moving parts.
If it is the compressor making noise, it needs a compressor but the fact you said the AC is still working makes me think it may be something else. (I have had noisy compressors that still functioned, but they were a very consistent whine, like a power steering pump low on fluid, or consistent chattering) I'd make sure the fasteners for the compressor are good and tight.
